  2. Introductions
  3. Introductions
  4. Jetta from St cloud
Jetta from St cloud
708 Posts 52 Posters 50.4k Views
  • 320dubbin3 Offline
    320dubbin3 Offline
    320dubbin
    funky_monkey58;290191 wrote:
    I thought the use of pie cuts was pretty good to get that 4" pipe to fit without modifying the firewall at all.
    Would you like to make another stupid statement about my car?
    well if I saw the car close up I would probably have input, but I haven't so I'm out of this one.
      320dubbin3 Offline
      320dubbin
      invest in a mandrel bending machine?? could bend your way out of problems!
      • funky_monkey58F Offline
        funky_monkey58
        That is how it was when I drove it to the CHARITY car show, I also donated T-shirts and what not for the cause.
          Must be a hot idea then, since Ive seen similar things on so many other supras.
          You never thought of having a pipe bent to fit it? Maybe that would be too simple for you. You could have even notched your firewall, you said yourself you like to fabricate things. You must enjoy it since you do so much of it. It would have made it look less terrible and not like an 8th grade welding project.
          You're right though, I guess I would waste a lot of time making something that flows terribly and looks twice as bad too.
            320dubbin3 Offline
            320dubbin
            I better go onto vwvortex quick and let them all know the new name for Vw's. this word is "douche canoe" think they would get mad at me? lol!!
              funky_monkey58
              Having a 4" piece of tubing at that extreme is not happening. You have no fucking inch of an idea on things are made do you?
                Your motor is clean, but your down-pipe looks terrible. And you should have sold the T-Shirts to fund the purchase of bending machine.
                  320dubbin3 Offline
                  320dubbin
                  funky_monkey58;290197 wrote:
                  Having a 4" piece of pipe at that extreme is not happening. You have no fucking inch of an idea on things are made do you?
                  o c'mon a mandrel bender can bend pretty well. it all depends on who is using it i guess. If you are good at using the machine you are capable of a lot of things. you think you have a space issue under the hood of your car?? try working on a 300zx. gotta pull the motor for almost everything. those cars with their engines aren't an easy task.
                    At that extreme? I'm sorry but that's not an extreme. In fact, I'm willing to bet that every other supra with that setup has run into the same issue and found other ways to fix it. And if they didn't run into that issue, then you just did something incorrectly in your thought process.
                    And it's clearly you that has no idea, or you wouldn't have wasted your time and metal on that "pipe" you have on it now. I'm not even sure one could call that a pipe. The more I look at it, the less and less it looks like it should be on a car. Bending a pipe to fit that angle and turbo outlet would have saved you a lot of stress I'm sure.
                    But whatever helps you sleep at night I guess...
                      320dubbin;290193 wrote:
                      invest in a mandrel bending machine?? Could bend your way out of problems!
                      hahaha
                        funky_monkey58
                        Function>Form.
                        Although you wouldn't understand this concept after all you did purchase a VW.
                        DelSlow;290202 wrote:
                        hahaha
                        I think this man knows something you don't.
                          will you stop using the word pipe? it's "tubing" you dumb shit.
                            funky_monkey58
                            This pic was taken at the car show that you saw my POS at.
                              Right. So that is why they call it a "downpipe", or "turbo-outlet pipe" and not a "downtube"... makes perfect sense. not to mention a pipe and a tube are the same thing. You should correct the people that actually have poor writing and notation skills.
                                funky_monkey58;290203 wrote:
                                Function>Form.
                                And here we are once again, the part where you criticize VWs for no logical reason whatsoever. You seem to revert to this when you run out of things to say. Maybe you should take some time to gather new insults...
                                  no tubing is tubing and pipe is pipe.
                                  Calling a part of a car something doesn't change what it is made from.... so learn something.
                                    funky_monkey58
                                    I want to see pics of your whip.
                                    Maybe we should have a vote on which is a bigger pos my old beat up supra or your newer VW.
                                      Got it. I just installed a new downTUBE on my car. I'll remember that. I just learned something.
                                      Shocking that I learned something right funky monkey? Being that I own a VW and what not.
                                        How are we defining "pos". If you're referring to functionality, appearance, and reliability, then I don't think it would be much of a comparison.
                                        And you sure got me scared now with a vote taking place. God forbid the others on this forum dislike my car as much as you. I'll try not to lose any sleep over it though.
                                        It also amuses me that you would suggest such a thing. Perhaps you're just looking for some reassurance that you don't sound like an idiot right now. So by having others say that my car is a shitbox or a pos, you'll feel justified in your feeble remarks towards it.
                                          funky_monkey58
                                          [ame]http://www.youtube.com/watch?v=Sf8cM7f6P2I[/ame]
