  4. ATTENTION: farmers, harvesters, truck drivers, slaves, whatever you might be.
83 Posts 19 Posters 9.4k Views
  • GrrG
    GrrG
    god damn zac you have some large fields, must feel like your not getting anything done all the time
    • beachbum_jonB
      beachbum_jonB
      beachbum_jon
      from the 2nd picture is appears to be a half section? or maybe what i think is a fence line in the back ground is my imagination
      -John Adams, 1735-1826-
      • zbrownZ
        zbrownZ
        beachbum_jon;290480 wrote:
        ^9070?
        no we don't run the CR rotor machines, we run the CX walker machines
        we drop alot of straw and cut alot of wet grain running alot of tough straw through the machine; The conventional machines are better suited
        CX and CR machines are identical aside from the actual thresher, cleaning system and everything else is the same
        your telling me, I hate pulling into a full section when i am seeding, with one air seeder
        Most of our land is farmed either as a full section or half section..... yes easy to get alot done, but it is intimidating pulling into a field
        It is different worlds from here to there....... you guys spin from mud..... I spin pulling hills....... Pics dont do justice to the actual grade of the land
        dry land when seeding, pulling a 42' disk drill..... which I can pull super easy on flat land
        • T
          T
          thrash
          I helped some friends in the southwest harvest earlier this year. Working fields that were a full section tall was ridiculous... i was the cart driver. The cutters would get full at the north end of the field, the semis were parked at the south end. Blah.
          We had a cat 670b they were trying out, 35ft header on it.
          Some of the hills the tractor i was driving couldn't make in C or D range.. even empty.
          • beachbum_jonB
            beachbum_jonB
            beachbum_jon
            they weren't trying a cat 670b, they were trying a challenger 670b
            how big of cart? what tractor? just 1 combine? what header, mcdon? honeybee? maxflex?
            • zbrownZ
              zbrownZ
              that is the best thing we got this year..... the one machine has the new honeybee flex draper
              the sickle rides on air bags, and the throat is huge..... Mcdon can suck a dick, those things are a POS from what i have been around them
              • beachbum_jonB
                beachbum_jonB
                beachbum_jon
                ha actually that was ment for thrash, but i have heard that honeybees are the cats meow when it comes to drapers.
                • MisterCMKM
                  MisterCMKM
                  No till is for sissies
                  thrash;315544 wrote:
                  Ford is back :)
                  • GrrG
                    GrrG
                    disk ripper is FTW
                    • T
                      T
                      thrash
                      right.
                      the cart tractor was a deere 4640, the cart was probably 800-900 bu (it could unload all 3 combines)
                      They were also running Deere 9600 and 9610 combines. I don't know about the headers.
                      • dubbsyD
                        dubbsyD
                        thrash;291425 wrote:
                        right.
                        Well that's your problem...
                        • z31Z
                          z31Z
                          z31
                          MisterCMK;290323 wrote:
                          No pics of the muddy fields
                          Those buildings look like the same buildings MnDak beet plant in Wahpeton has.
                          • bubbaB
                            bubbaB
                            The piler looks a little different to me though...
                            • beachbum_jonB
                              beachbum_jonB
                              beachbum_jon
                              right.
                              buahaha you sure it was a 4640 and a 800bu? thats alot of cart of not alot of tractor! iv got 3 dumps on a 750bu cart before, and it was more like 700bu, because you can hardly ever fill a "square" cart up full like you can a longer 1000bu cart
                              • dubbsyD
                                dubbsyD
                                oh a 4640 will probably pull 800bu but it sure won't like it and it'll be even angrier if you start up a hill. I've pulled a Brent cart with wet corn running over on each side (right around 750-800bu) with a 4650 - just don't make real good time, steer with the brakes, and pucker up the first bump you hit. They finally stepped up to an 8200 a couple years ago and now this year will be pulling it with a smaller 4WD JD (9x00?).
                                That is of course assuming they ever get done with soybeans. I'm trying to save up some PTO so I can spend time in the semi hauling wet corn again but the way the weather is looking they might be combining the corn in the spring.
                                • beachbum_jonB
                                  beachbum_jonB
                                  beachbum_jon
                                  yeah, the engine will pull it, it will be a load, thats for sure, but it will pull it. but thats not what i would be worried about. what i am worried about is the draw bar. the amount of weight that is put on the draw bar that it wasnt designed for is immense. like we tell all of our workers, we would rather have the combine have to slow down or stop, rather than bust a draw bar and have to have the tractor down until we can replace it. so we make sure all of our workers slow the fuck down in a rough spot and if they are heavily loaded, just take it easy, we will understand if they are late getting back to the combine
                                  • T
                                    T
                                    thrash
                                    the combines were a 9600, 9610, and a 670b, which have hoppers of 240, 240, and ~300 bu. The cart could take all 3 combines, full.
                                    • beachbum_jonB
                                      beachbum_jonB
                                      beachbum_jon
                                      ~900bu with a 4640? im not saying you are lying, but i would have to see pictures.
                                      • MisterCMKM
                                        MisterCMKM
                                        And this brings me to my next point, John Deere = weaksauce
                                        Ford is back :)
                                        • z31Z
                                          z31Z
                                          z31
                                          ^^^Kind weak guys.
