  4. ATTENTION: farmers, harvesters, truck drivers, slaves, whatever you might be.
83 Posts 19 Posters 9.4k Views
  • bubbaB
    bubbaB
    z31;291431 wrote:
    Those buildings look like the same buildings MnDak beet plant in Wahpeton has.
    The piler looks a little different to me though...
    • beachbum_jonB
      beachbum_jonB
      beachbum_jon
      thrash;291425 wrote:
      right.
      the cart tractor was a deere 4640, the cart was probably 800-900 bu (it could unload all 3 combines)
      They were also running Deere 9600 and 9610 combines. I don't know about the headers.
      dubbsy;291429 wrote:
      Well that's your problem...
      buahaha you sure it was a 4640 and a 800bu? thats alot of cart of not alot of tractor! iv got 3 dumps on a 750bu cart before, and it was more like 700bu, because you can hardly ever fill a "square" cart up full like you can a longer 1000bu cart
      -John Adams, 1735-1826-
      • dubbsyD
        dubbsyD
        oh a 4640 will probably pull 800bu but it sure won't like it and it'll be even angrier if you start up a hill. I've pulled a Brent cart with wet corn running over on each side (right around 750-800bu) with a 4650 - just don't make real good time, steer with the brakes, and pucker up the first bump you hit. They finally stepped up to an 8200 a couple years ago and now this year will be pulling it with a smaller 4WD JD (9x00?).
        That is of course assuming they ever get done with soybeans. I'm trying to save up some PTO so I can spend time in the semi hauling wet corn again but the way the weather is looking they might be combining the corn in the spring.
        • beachbum_jonB
          beachbum_jonB
          beachbum_jon
          yeah, the engine will pull it, it will be a load, thats for sure, but it will pull it. but thats not what i would be worried about. what i am worried about is the draw bar. the amount of weight that is put on the draw bar that it wasnt designed for is immense. like we tell all of our workers, we would rather have the combine have to slow down or stop, rather than bust a draw bar and have to have the tractor down until we can replace it. so we make sure all of our workers slow the fuck down in a rough spot and if they are heavily loaded, just take it easy, we will understand if they are late getting back to the combine
          • T
            T
            thrash
            the combines were a 9600, 9610, and a 670b, which have hoppers of 240, 240, and ~300 bu. The cart could take all 3 combines, full.
            • beachbum_jonB
              beachbum_jonB
              beachbum_jon
              ~900bu with a 4640? im not saying you are lying, but i would have to see pictures.
              • MisterCMKM
                MisterCMKM
                And this brings me to my next point, John Deere = weaksauce
                thrash;315544 wrote:
                Ford is back :)
                • z31Z
                  z31Z
                  z31
                  ^^^Kind weak guys.
                  • MisterCMKM
                    MisterCMKM
                    Safe-T-Pull FTW
                    Are you guys hauling now? We've been shut down for a few days now and the rain isn't helping.
                    Ford is back :)
                    • z31Z
                      z31Z
                      z31
                      MisterCMK;291686 wrote:
                      Safe-T-Pull FTW
                      No, we shut down about 4 pm yesterday. I just thought i would post the pictures.
                      • MisterCMKM
                        MisterCMKM
                        How about some broken parts? The apron shaft on the harvester broke last night. We had the new parts in the shop by 2:00am but then the fucking rain came.
                        Ford is back :)
                        • ParkerP
                          ParkerP
                          Colin FTW...
                          BlueSRT0483;244555 wrote:
                          Trafik Jamz;260984 wrote:
                          You are right Parker.
                          • MisterCMKM
                            MisterCMKM
                            Indeed
                            Ford is back :)
                            • STiSchuckyS
                              STiSchuckyS
                              fuck harvesters for making every rural road a mud slide.
                              that is all
                              • z31Z
                                z31Z
                                z31
                                Fall sugarbeet harvest keeps getting better and better.
                                • ParkerP
                                  ParkerP
                                  that is all
                                  you're welcome....
                                  • MisterCMKM
                                    MisterCMKM
                                    that is all
                                    Harvesters don't make the road muddy. I believe you confused harvesters with trucks. A common mistake...
                                    Ford is back :)
                                    • beachbum_jonB
                                      beachbum_jonB
                                      beachbum_jon
                                      that is all
                                      did you eat anything this week?
                                      that is all
                                      • MisterCMKM
                                        MisterCMKM
                                        Mud on the road + not scraping it off the pavement + truck =
                                        Ford is back :)
                                        • z31Z
                                          z31Z
                                          z31
                                          ^^^ Let me guess who was driving? :icon_scratch:
