  4. Project FD: Took way too long
45 Posts 19 Posters 3.9k Views
    fdfreak;292756 wrote:
    oh, sorry. yeah, I have been talking to this guy in Green Bay who has been racing rotarys for 20+ years. He just took apart his 500hp setup he has been running for the last 4 years with 16k mi on it. there was nothing wrong, he was just curious to see what it looked like. He said that it looked just as good as when he put it together. Everything was with in spec.
    I have very little knowledge about AI , but if it worked for him i figured i would give it a try. If you have any pointers zbrown, please advise.
    Yeah there is so much good info on the AI section of rx7club it is crazy, that is the only reason i go there now. haha
    what system are you using?
    The only thing that sucks about spraying a ton of meth is the effect on your main fueling, since you have to pull so much fuel out. and if something happens to the AI you are SOL with an engine that doesn't like hiccups.
    I had mine setup to where the standalone progressively controlled the duty cycle of the AI pump with PWM (AI had its own rpm/load map)..... so there wasn't 2 separate systems.... better, more consistent, and reliable IMO
    I like meth, but am a fan of water too
    I would run E85 with some, not a ton, of meth/water on the top..... and IMO have as reliable rotary setup as you are going to have
    • fdfreakF Offline
      fdfreakF Offline
      fdfreak
      yeah, actually Howard Coleman is a big contributer to that AI section at Rx7club. He is the one i have been talking to. That guy has a wealth of knowledge.
      12.645@118mph 12.6psi
      • capitljC Offline
        capitljC Offline
        capitlj
        Sexyness. I hope your trianglemabob does last, what I mean is I wish you luck.
        > Mitch Hedberg wrote:
        2004 Impala LS 3.8
          I thought you painted the car yourself earlier this summer?
          • fdfreakF Offline
            fdfreakF Offline
            fdfreak
            I did and it turned out looking like crap. It looked fine when it was in the shop but when i pulled it outside, it was blotchy as hell.
            • wishinskyW Offline
              wishinskyW Offline
              wishinsky
              Think looks sick! Like the lip it makes the front bumper look a lot better i think. Very nice car.
              -Cars i drive
              2002 Mustang
              1997 Bravada Smart Track
              • Toys
                05 TTR 125 L/LE
                02 YZ 85 with 110cc kit
              • 99civic9 Offline
                99civic9 Offline
                99civic
                svxAL;292739 wrote:
                did u have the bumpers off when u painted it ? how bout trim pieces? jw btw
                nope everthing stayed on the car... not bad for doing in in my garage and for my copressor to have sand in its vagina....
                2000 civic SiR - jdm sickness
                  you didnt take em off?...
                  • fdfreakF Offline
                    fdfreakF Offline
                    fdfreak
                    the lights, side markers, mirrors, side skirts, and front lip were all off before paint
                      So the door jams are still red too?
                        That is a very nice looking car, glad to see you got the roof straight
                        And i ran straight meth for a looooong time too, actually over 100 gal of it over a couple years, works great. BUT, i had a block with 2 broken pistons from when the pump quit one day. Go straight E85 and you would be far, far, far ahead man
                        • fdfreakF Offline
                          fdfreakF Offline
                          fdfreak
                          no, those are blue. I left those from when i painted it the first time. the only thing left that is red and visible is the under side of the hatch.
                          • fdfreakF Offline
                            fdfreakF Offline
                            fdfreak
                            that roof took me a solid 10 hours to get the dents out, bondo, and sand. Unless it is very minor, I will never do body work ever again, i hate it with a passion.
                            • Chance91C Offline
                              Chance91C Offline
                              Chance91
                              Sounds fun, and the car really looks solid man.
                              Btw, Who did your rebuild, and what turbo are you running now?
                              3mm Apex seals?
                              • fdfreakF Offline
                                fdfreakF Offline
                                fdfreak
                                Well after trying to rebuild it myself and losing compression everytime i sent it to a WI to a guy by the name of Howard Coleman. He put a pretty agressive port on top of the one I already had. And no, I am running 2mm. And I am running an ATP To4z turbo. thanks for the compliment.
                                  Pressure switch could have been used to detect loss of pressure and shut down fuel/ignition to keep that from happining. I think the chance of those pumps failing are the same as a fuel pump failing. it happens. but not enough for me to be affraid to use it.
                                    it's always good to see someone keeping a rotary in their 7...
                                    • Chance91C Offline
                                      Chance91C Offline
                                      Chance91
                                      That's a good way to run it. I'd prefer to have a standalone that can control the Meth as well, but they're aren't a ton of them out there, and they get pretty spendy.
                                      I think the Haltech unit for the RX-7 is capable of h20/metch injection handling.
                                      The Hydra is, but I don't think its offered for the rotaries, and its an $800 option... YIKES
                                      In other news.. I really want to learn how to rebuild these things...
                                        careful with what you say..... as the motor is usually out of the car as much as it is in....
                                        • fdfreakF Offline
                                          fdfreakF Offline
                                          fdfreak
                                          ^lol, true
