  4. Attention Euro owners/fans
44 Posts 21 Posters 2.5k Views
  • Bp-08B Offline
    Bp-08B Offline
    Bp-08
    thrash;293222 wrote:
    A lot of ass-talking here.
    Chuck, I have an 07 A4 2.0T 6 speed wagon and its the fucking balls. I've got 30k miles on it. Zero electrical problems. It is loaded.. I think the only factory options it doesn't have are Sat Radio and the S-line appearance package. The factory Nav, Bluetooth, etc are great. My wife loves it and so does my kid. Gets 31mpg pretty regularly, can still fit [some] 16 rims for cheap snow tires. Extremely quiet.
    I've had two issues on the car:
    • intermittent soft brake pedal in extremely hot weather
      -- dealer figured it was probably a master cylinder issue. I need to do the brake fluid soon and if after bleeding and putting in superblue i still get this, i'll probably raise a stink over it to get them to fix it.
    • a rough idle / cold start problem that was fixed by replacing a hose [or something]
    The B7 is a huge leap forward over previous audis. The 2.0T engine is great and the factory brakes are finally good enough [320mm vented fronts].
    The 2.0T is flashable and supports multiple programs.
    APR and GIAC are the biggest vendors. With APR at least, you do have to go to an authorized dealer to have the flash done -- they don't give you "rom.zip" and tell you to party.
    Intake and BOV mods are not useful. Exhaust is, with downpipe being more useful still. Several are available. A cat back on this car is normally full stainless and is around $1k.
    K04 and GT28 turbo kits are showing up, and are both spendy ($4-6k)
    The complicating factor for big power on the 2.0T is that it is DI, so to get more fuel in there you are messing with an outrageously high pressure fuel system. The mechanical pump is cam driven. APR makes a fueling kit that seems to work well for people.
    Additionally, it looks like even on stock vehicles the fuel pump cam follower is a wear item; not replacing it soon enough will eventually cause lobe wear on the cam shaft. It's a DIY job and a dealer won't touch it unless an MIL is lit. I haven't looked at mine yet, fwiw.
    If you want to stop by and check it out later tonight I'm available.
    Do you think 30k miles is a lot or something?
      thrash
      You should ask a moderator to delete my message. Clearly you are adding more value to the discussion.
      • Bp-08B Offline
        Bp-08B Offline
        Bp-08
        So you had problems with your car and it only had 30k, and you think its reliable? Why would I ask a mod to delete your message, its a damn internet forum, you going to cry now.
          thrash
            maybe chuck would get more information if the only people who respond are the people with direct experience with newer vw/audi vehicles?
            the only problems i've had with my car include the one-touch window controls and how they sometimes move the window back down after going up with the one-touch functionality. granted, i may just need to pay closer attention to how far a push the switch when closing the window.
            if anyone here had any useful information about ecu options, they would have made reference to ross-tech or vag com http://www.ross-tech.com/index.html
            • Bp-08B Offline
              Bp-08B Offline
              Bp-08
              thrash;293241 wrote:
              once your car makes it to 230,000 miles on the original fuel pump, tranny, and motor, you can tell me how good euro cars are. My exploder did, and I beat the crap out of it. I was 15-16 when I had it neutral bombed it many times. All I ever had to fix on that on the 6 years we owned it bought it in 2000 and sold it in 06 or 07 was an cv boot because i tore it on a rock out hunting. My current car is at 216,000 and I just recently replaced the original thermostat. The tranny did go out but that was my fault at 180,000 miles. and its a ford.
              • drift86D Offline
                drift86D Offline
                drift86
                Shut up^^^
                AE86 project: sold
                93 r33 gts25t new project
                00 impreza obs
                  thrash
                  h0 h0 h0!
                  There is a 200,000 mile BMW in my garage right now. 3 of the 6 German cars I've owned were in the 200,000 mile range.
                  I fondly remember the decidedly non-German cars that left me stranded though:
                  • My 85 Bronco II's engine sputtered out and died and wouldn't refire. I was driving it up a mountain and it just ran out of air or something. After I had it towed back down the mountain, it started back up again. Tow truck driver laughed at me. Go Ford!
                  • My 70 Cutlass blew its engine, because I had the nerve to run it wide-open on the interstate for about 30 mins [it would only hit 90mph.. wtf kind of peice of shit is that?].
                  • My 91 celica had 3 clutches in the time we owned it. I let a friend borrow it and she shredded what was left of it, leaving her stranded on the highway in Seattle.
                  I've done hundreds (if not thousands) of laps of BIR in high-miles BMWs. Then I drive them back to Fargo when I'm all done. I think the only on-track issue I had was throwing a belt. Went to napa and threw on another one, and that was that. I was back out for the next session.
                  IIRC, on the Ferrari 355 you pull the engine out of the car every 15,000 miles to do an engine service. Is it unreliable? Should Ferrari owners drive ford explorers?
                  Stop shitting in this thread -- it's a question about a specific car, not a solicitation for uninformed anecdotes.
                    • KossickK Offline
                      KossickK Offline
                      Kossick
                      HAHAHA +1 to anyone who brags about a high miled explorer... that takes balls, right?
                      2012 Volkswagen CC Lux Plus
                      • blackcherryTSiB Offline
                        blackcherryTSi
                        Eurofan;293193 wrote:
                        To do cosmetic mods: h&r lowering springs, Wheels (VMR 710's), debadge, and tint.
                        like EVERY OTHER euro car.... atleast with the JDM'ers there is a wide variety of customizing.... not just the same old debadge,slam,stretch,tint song and dance
                        1995 Honda Civic
                        • Bp-08B Offline
                          Bp-08B Offline
                          Bp-08
                          You cant blame the car for the clutches going out, thats something called being a shitty driver.
                          And yes, yes they should.
                            Lol i think you're talking about VW guys
                              blackcherryTSi
                              my apologies good sir... most commonly describing those dreaded VDub guys lol
                              1995 Honda Civic
                                • GoodnbuzzdG Offline
                                  GoodnbuzzdG Offline
                                  Goodnbuzzd
                                  I have over 200 thousand on my Mercedes The only parts that have been replaced are the Ignition switch and the starter.
                                  As for the Audi's I think its hit and miss, i have heard both sides. however, my buddy, yes the same guy Ichi was talking about has an a4 and had many electrical problems, ABS, Airbag readiness lights, Cold start valve issues, idle control issues, window elevator breaking, and vacuum system problems. seems like he takes it to get repaired and within a month or two there's more shit to fix. It's a nice car, and fun to drive, but it is a money pit repair wise.
                                    Eurofan;293194 wrote:
                                    These are the VMR 710's with a drop. Pure sex.
                                    looks like a VW....
                                      Trafik Jamz
                                      24valvenotak;293212 wrote:
                                      is it getting too crowded over there on the urabus bandwagon?
                                      Shit, I've been on the WRX bandwagon since 2001....
                                      701.541.3484
                                        Trafik Jamz
                                        My 1999 Chevy 3/4 ton is at 268,XXX miles right now, that must mean that it is the best tuner car around....right? My WRX broke a ring land at ~30,000 miles meaning it is utter horseshit I assume?
                                        701.541.3484
                                          Trafik Jamz
                                          Sorry guys, I'm going to take the advice of thrash/jim/eurofan on this. They seem to have a better feel for what is going to happen if I just buy the car to drive. Not to race, not to mod (extensively), etc...just to drive from home to work and back again and the occasional trip out of town.
                                          701.541.3484
