  4. 2010 m3 gts..wow
2010 m3 gts..wow
135 Posts 23 Posters 5.2k Views
  • T
    T
    thrash
    You made several ridiculous claims about A4s which I put to rest with prejudice.
    If you find something factually errant that I wrote, say so. If you disagree with a subjective conclusion I have reached, explain what and why you disagree.
    • BryceB
      BryceB
      Busting out your hidden debate skills along with your internet thesaurus for this reply.
      • SPANISH-RICES
        SPANISH-RICES
        my claims on A4's were facts, i even cited the source. proving that base model euro cars ARE NOT SPORTS CARS. i may have been wrong about the weight becuase i converted from kg to lbs in my head very quickly while doing things at work.
        but now on the other hand YOUR RIDICULOUS CLAIMS include:
        • that european sports cars are the majority of cars driven over japenese vehicles.
        • that base model european cars, no matter how slow and gay, are still faster than ANY base model japanese cars?
        • that your idea of a sports car is a 150 flywheel horsepower car that can sustain 130MPH
        now besides comparing economy civics to gt4's what actual evidence do you have that european cars, THAT ARE NORMAL DAILY DRIVEN VEHICLES, would out perform on the track?
        • E
          E
          Eurofan
          Fail.
          Look at this simply
          Take a base a4/328i/128i then take a base honda whatever.... or even a type r
          Germans engineer things on a different level... Like I have been saying before they are able to do this because their base prices are higher.
          Go talk to Honda's production team...
          They do not engineer base model hondas off performance (any of you losers who think your stock hondas are fast.. I pity you). THEY ARE FUCKING ECONOMY CARS!!!!!! YOU FAIL!
          German cars on the other hand, FOR THE MOST PART, are always built with some performance aspects in mind due to the fact that they HAVE TO engineer them on another level... they always keep the autobahn in mind.
          Yes I am comparing hondas and bmw's/audi's....
          Would you like me to compare the Lexus is250 with the BMW 328i??? It would have the same end result. Or perhaps the Acura TSX vs the audi A4 2.0t?? The outcome is always the same.
          We can compare on the next level as well... Would you like me to compare the lexus IS-F and the BMW m3???
          The s class mercedes vs the Acura RL
          The 7 series Bimmer vs the lexus LS.....
          Its always the same. The performance numbers favor the Germans. Over and over and over and over again...
          • E
            E
            Eurofan
            SPANISH-RICE;293575 wrote:
            1998 AUDI A4 SPECS
            Turbo compressor
            • 1,781 cc 1.8 liters 4 in-line front longitudinal engine with 81 mm bore, 86.4 mm stroke, 9.5 compression ratio, cast iron block, light alloy head, double overhead cam and five valves per cylinder
            • Premium unleaded fuel
            • Fuel economy EPA highway (l/100km): 8.1
            • Multi-point injection fuel system
            • 60 liter fuel tank
            • Power: 112 kW , 150 HP @ 5,700 rpm; 155 ft lb , 210 Nm @ 1,750 rpm
            TAKEN FROM INTERNETAUTOGUIDE.COM
            <u>150 FLYWHEEL HORSEPOWER</u>
            YOUD BE LUCK TO SUSTAIN 105 MPH FOR 10 MINUTES WITH THAT MOTOR TRYING TO MOVE A 3500 LBS CAR. BLOW ME REFLECT THAT RACE INSPIRED BULLSHIT
            How much HP did honda have in their base model car??????? Just stop.
            • zbrownZ
              zbrownZ
              zbrown;293540 wrote:
              Euroboy is a toolshed
              So you are trying to tell me the budget ZR-1 gets slaughtered on the track by the big dog $$$$ euros huh?
              bump to toolshed.... answer my question
              • PSiedTSiP
                PSiedTSiP
                There is no answer, you can't compare a "supercar" to a Euro sedan...
                spanish-rice;237125 wrote:
                • E
                  E
                  Eurofan
                  The ZR1 is a beast in most performance respects. Along with the GTR and the new CTS-V
                  There is no denying that. But like I said before... For every ZR1, GTR, and CTS-V there are 15 german cars that can do it just as good...
                  • E
                    E
                    Eurofan
                    "toolshed"
                    Are you done??? Seriously grow the fuck up.
                    • zbrownZ
                      zbrownZ
                      right....
                      Did i hurt your feelings Mr. Shed?
                      • zbrownZ
                        zbrownZ
                        Oh, and where is the ZR1 lacking in some performance respects??
                        • DelSlowD
                          DelSlowD
                          Well im pretty sure on average a stock b16 is 160ish..soo...
                          Eurofag fail?
                          • T
                            T
                            thrash
                            You said the A4 had 140hp which was wrong and you said it weighed 4300 lbs which was also wrong. Those are the only to objective things you said about it, which were both wrong [and obviously so].
                            What reason is there to suggest you can get anything else right?
                              i never said any such thing
                            I never said that either.
                            Nor did i say that. Actually, my idea of a sports car is one with probably only about 150hp, but its RWD, a convertible, and only 2 seats. And its absolutely under 3000 lbs. So about the only sports car left these days would be the Miata and the Elise.
                            I don't even know what a GT4 is. Are you talking about a celica GT4 or a 3000 GT VR-4? Or something else entirely?
                            You are getting really bent out of shape over things you have surmised that I've said that I never did.
                            Here is the short version of what I said: in the US, German cars cost more because only the expensive ones come here, and those cars have a higher level of in-built capability regarding sustained high speed operation because that is a requirement in their home market. As such, they tend to be over-represented at track events in the united states compared to the more economical models from Japanese and domestic suppliers. Notable exceptions to this are the occasional few interesting japanese vehicles -- like the NSX, S2000, etc, all of which happen to be sporting purposed and cost more than the base models that people typically are talking about when one is discussing "imports".
                            Have you ever driven at BIR? Or anywhere, really? Did you pay attention to what stock vehicles people were driving? And what was fast?
                            • DelSlowD
                              DelSlowD
                              Zac, stop arguing with him. Cant you see that all Euro cars are built with performance in mind. Duh. I mean read his posts, he asked up to go speak with Honda's engineers. By saying this, clearly he has a degree in engineering and has spoken to eUrO car producing engineers.
                              Obviously he is such a fucking toolshed and clearly blinded by his Guido like Euro cars' awesomeness.
                              Oh and I still lol at the fact that he doesn't realize that 'most euro cars' are fucking yugos and le cars...fucking idiot.
                              • SPANISH-RICES
                                SPANISH-RICES
                                eurofan;293602 wrote:
                                how much hp did honda have in their base model car??????? Just stop.
                                youre the one saying that euro cars outperform anything on the streets. I never came in here talking shit about euro cars, youre the one that brought japanese cars into comparison. Im just comparing them accuratly, something you cant grasp.
                                Did i say base model hondas are race tuned? No. Did i say a base model japanese car would smoke a similarly priced base model euro car? Yes. Its true. And im still waiting for any form of facts from your end to prove me wrong.
                                Maybe instead of your euro engineers designing their cars for "performance" they should design their wiring to work properly past the warranty. That would be a good start
                                • DelSlowD
                                  DelSlowD
                                  This is the best quote by you I think. LOL
                                  • JimJ
                                    JimJ
                                    They are too busy eating sauerkraut and wienerschnitzel to make the wiring work correctly... you should know this!
                                    I guess the japs are too busy eating rice and hot dogs to make their cars perform on the tracks then... lol
                                    • DelSlowD
                                      DelSlowD
                                      I guess the japs are too busy eating rice and **dogs **to make their cars perform on the tracks then... lol
                                      Fixed.
                                      • JimJ
                                        JimJ
                                        DelSlow;293619 wrote:
                                        Fixed.
                                        Jap's dont eat dogs. Koreans do, thats Hyundai fool. KDM yo
                                        • DelSlowD
                                          DelSlowD
                                          Japs...Koreans...what's the difference?
