  2. Local Shops and Businesses
  3. Straightline Detailing
  4. Headlight Reconditioning
27 Posts 9 Posters 2.6k Views
  • wesholeW
    wesholeW
    Looks like the same kit we use here Kevin. Shit works awesome.
    • A
      A
      aliengotpsi
      Wes its, sand paper, Air DA sander, Dewalt buffer, mini polisher, UV clear coat..
      How much do you charge ? How many do you guys do?
      Kevin Smith
      Straightlinedetailing.com
      • svxALS
        svxALS
        svxAL
        do you 1500 then 3 or do u cut a little deeper seem to do alot of these at school
        94 Subaru SVX FWD
        subaru-svx.net
        1999 silverado
        • A
          A
          aliengotpsi
          Most cars get sanded W/
          240
          400
          600
          1000
          1500
          Then buffed
          Cleared w/ uv clear
          Kevin Smith
          • wesholeW
            wesholeW
            Here's the kit we use.
            http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Featured_Products/Headlight/
            We charge $50/pair to do the job. Unfortunately, we have not been doing the u/v clear afterward. That is something we have not had the resources to get ahold of. Is what you use in aerosol can or applied using a gun?
            • svxALS
              svxALS
              svxAL
              [QUOTE=aliengotpsi;293832]Most cars get sanded W/
              240
              400
              600
              1000
              1500
              Then buffed
              Cleared w/ uv clear[/QUOTE
              really 240 lol holy shit ive took headlights out of the junkyard and 1000 was the most coarse I got and they looked brand new i mean they were bad you couldn't even see inside to the reflector. dont you think its a little over board to do clear or does it just help so they dont get crapped up within the next couple years
              94 Subaru SVX FWD
              subaru-svx.net
              1999 silverado
              • bubbaB
                bubbaB
                240
                400
                600
                1000
                1500
                Then buffed
                this is what i was thinking too...
                • A
                  A
                  aliengotpsi
                  240
                  400
                  600
                  1000
                  1500
                  Then buffed
                  Would you buff and polish a car and not protect it? What you are doing when you sand the headlights you are removing a OEM coating that had been broken down by the UV- Rays/Bugs/etc.
                  On some car 240 is over board but then if you have some like cadillacs they have a much harder coating on the headlight and takes longer using higher than 240.
                  The coating we have been currently using is a wipe on on. but others we have are spray on and have to be cured with a UV LIGHT.
                  Kevin Smith
                  • A
                    A
                    aliengotpsi
                    Wes thats a good kit.. You may want to jump up to a full size buffer to make polishing out the sanding marks faster and use the small DA polisher for the hard to reach areas..
                    Kevin Smith
                    • wesholeW
                      wesholeW
                      What clear are you using Kevin?
                      • svxALS
                        svxALS
                        svxAL
                        aliengotpsi;293868 wrote:
                        [quote=svxAL;293850]
                        Would you buff and polish a car and not protect it?.
                        i geuss im confused at this ussaully after i pull a car outta the booth i cut it then buff it then polish then run it out the door thats how i was taught and how most body shops do it :icon_scratch:
                        94 Subaru SVX FWD
                        subaru-svx.net
                        1999 silverado
                        • A
                          A
                          aliengotpsi
                          svxAL;293871 wrote:
                          [quote=aliengotpsi;293868]
                          After you polish a car you need to wax or seal it , unless its fresh paint. But I do love fixing body shop buff jobs... Newbs Leaving swirls, holograms,fish-tails, sanding marks, compund in the cracks... If you work at a body shop you should know what I mean. Very few do a decent job. im sure the reason is that it may take days to wet sand and buff , polish to make a car perfect..
                          Kevin Smith
                          • svxALS
                            svxALS
                            svxAL
                            aliengotpsi;293872 wrote:
                            [quote=svxAL;293871]
                            well i guess ive only done freshly painted vehicles and a few scratches on friends cars. and well I geuss I wet sanded with 3000 my whole car the buffed and polished it and it looks really good took out almost all imperfections. and as for the compound getting all over that's what the detail/recon place is for cleaning the vehicle we fix. It then goes to them to clean and make it look good. And as for swirls and some LITTLE sanding marks/dull spots sometimes u miss them when u have half a car that needs to be cutt buffed, polished and throw back together than to recon to be detailed and back to the owner that day lol.
                            94 Subaru SVX FWD
                            subaru-svx.net
                            1999 silverado
                            • A
                              A
                              aliengotpsi
                              Which body shop do you work at?
                              Kevin Smith
                              • svxALS
                                svxALS
                                svxAL
                                i worked at a dealership body shop all summer and prolly going to again when i graduate this spring from college
                                94 Subaru SVX FWD
                                subaru-svx.net
                                1999 silverado
                                • wesholeW
                                  wesholeW
                                  Kevin, you never did answer my question. What are you using for the UV coating?
                                  • A
                                    A
                                    aliengotpsi
                                    ReNulite Clear
                                    SEM Clear
                                    Liquid Resin Clear
                                    Used all 3
                                    Kevin Smith
                                      I have a 1998 Ford Explorer, this procedure didnt wotk to well so i just bought 2 new headlight assemblies--works alot better.
                                      Be safe
                                      • DrifterExtremeD
                                        DrifterExtremeD
                                        damn bots
                                        • T
                                          T
                                          Trafik Jamz
                                          spambot eliminated
                                          701.541.3484
