Stuck in 3rd Gear!!!!!
many automatic transmissions have a "limp mode" whereby if something is wrong with the TCU or ECU->TCU wiring [or the transmission itself], the transmission will only operate in 3rd gear.
I have no idea if an acura LS would have this feature or not. Something to look into.
thrash;293851 wrote:
many automatic transmissions have a "limp mode" whereby if something is wrong with the TCU or ECU->TCU wiring [or the transmission itself], the transmission will only operate in 3rd gear.I have no idea if an acura LS would have this feature or not. Something to look into.
wouldnt be an auto if he said it'll shift into "1,2,3,4,5 and reverse" itd be 1,2,D(3),N,reverse
It's not the linkages. It's likely a broken fork.
integra_gsr98;293918 wrote:
It's not the linkages. It's likely a broken fork.I thought I had posted this in my drunken stupor the other night as well. Wouldn't you be able to use 3rd and 4th tho? I know when I broke a fork, I could use 3rd and 4th.
Either way, if it's just a fork, thats a simple/cheap fix, if you can pull the tranny and the case yourself.
When I broke a fork on my DSM it got stuck in one gear....
