  3. Run Your Mouth
  4. /sigh VW Owners......
13 Posts 11 Posters 3.0k Views
  • E Offline
    E Offline
    Eurofan
    Such a fail.
      Eurofan;294480 wrote:
      Such a fail.
      don't cry.... it's ok...
        A little JB weld will put that right back to new....
          thrash
          this is the most fail ever. Taking the entire rear corner off at the suspension side of things is fewer than 10 fasteners.
          If there was truly no way to work that thing out from the front, taking the whole suspension corner off and then getting at it from the back [or cutting the hub, for that matter.. as a hub + bearing assy is cheaper than the wheel.
            I had to do something like that when freaking all 4 of my wheel studs when completely loose and grooved everything out...lucky I caught it before anything really happened.
              And got lucky that you could buy a whole nother hub assembly for cheap.
              • RaiderR Offline
                RaiderR Offline
                Raider
                one of my techs had over 4 hours removing siezed/broken studs on a benz
                POWERD BY
                  further proof vdubbers are retarded..
                  • E Offline
                    E Offline
                    Eurofan
                    On a single car??
                    Lol?? :icon_scratch: thats pretty crazy...
                      Must be those high performance race inspired lug bolts
                        Total fuckin idiots. Had a BMW do the same thing. Drills go a long way. Cut the wheel off? TOOLSHED!!!!!
                        • RaiderR Offline
                          RaiderR Offline
                          Raider
                          Eurofan;294544 wrote:
                          On a single car??
                          yes..not sure if you have seen the bolt on a older benz but they had broken off right at the bevel and he had to drill everyone...some of them broke off flush but most of them left a 1" of stud before the bevel...he went through a ton of drill bits
                          POWERD BY
