  4. Car shops????
Car shops????
22 Posts 9 Posters 2.9k Views
  • My NOvaM Offline
    My NOvaM Offline
    My NOva
    hey im buying a engine rebuild kit from summit or jegs for 398.99 or somethin, what are the rates of some shops for rrebuuilding engines?
    Hey Tina come get some hamm
      WWWWWhy ccccan't yyyou ddddo iit yyyourself?
      • stephen bradleyS Offline
        stephen bradley
        ttthat fffuuunny 🙂
        • Unknown
        • My NOvaM Offline
          My NOvaM Offline
          My NOva
          cause im lazy what i ment was what shops are good to go to to get a rebuild if i bring them the parts not saying i cant do it i just dont have all the tools if i had a cherry picker engine stand a place to work plus tools i could do it
            That what freinds are for.
              I'm just saying that it's very easy to assemble. For christ sakes, it's a small block chevy. I've assembled countless chevy engines I could do it in my sleep. It would be alot cheaper for you to buy a 40-50 dollar engine stand and borrow/rent a cherrypicker and torque wrench than it would be for you to pay someone to do it. I've noticed that you've done everything else on your engine by yourself like switching heads and intake, why not take it on? It's alot easier to assemble or work on an engine out of a car than in one. And it only takes a little over an hour to pull one out of a car as old an simple as yours. Just my $.02.
                I am going to have to go with Wes on this one hell even I have had the opportunity to do a SBC rebuild. It is not that hard at all it is actually fun.
                • 94NDTA9 Offline
                  94NDTA9 Offline
                  I'm going to have to dissagree...at least for high hp engines...maybe not your case. Sure, I could throw together and engine to the best of my ability, but if I am going to be purchasing some very expensive internals, I would rather trust a known mechanic with expensive insturments over myself doing a backyard install. If your buying an engine rebuild kit for 389.00, you probably aren't going to be running too much hp, you could get away with doing it yourself.
                  • My NOvaM Offline
                    My NOvaM Offline
                    My NOva
                    i know i can do it its just i dont have space to do it i do but thats 50 miles away, i should be pushing 295 - 300 like normal in the summer plus some juice 😄 all those parts im buying are stock size pistons but high proformance rather then waitng for a bore ill just go this way but does any one have a cherry picker i could use? maybe even rent a space in a heated garage?
                      i'll come help ya nova! haha.
                        if you're going to have all this stuff apart why not go to a big bore, if that's what you would rather have?
                          yeah if you gonna plan on boreing it later....dont waste ur money on doing little now..and go big.
                          • 94NDTA9 Offline
                            94NDTA9 Offline
                            So you are going to rebuild your 350? Thats not the best Idea. If you are going high performance, you should at least bore it to a 355 to clean up the cylinder wall (especially if you are going to be on the juice). Also, I am assuming your 350 is in need of a rebuild, which would give even more reason to NOT slap a bunch of performance part into a 350 block. If you are going to do it, do it right, or do it half asses and run a greater possibility of ruining your engine.
                            Oh yeah, for a performance rebuild, if you are spending $389.00 I promise you that it will not be much stronger than your engine stock.
                            • My NOvaM Offline
                              My NOvaM Offline
                              My NOva
                              the engine is only 4 years old its not from 1970 so all i need to do is redo my bottom end cause my plan is to fix this motor do some runs at the track, save money to drop my ram jet air 350 in and have tufte do either a twin or single turbo setup
                              • 94NDTA9 Offline
                                94NDTA9 Offline
                                Why bother with a ram jet 350? Why not save up go a bigger cubed small block built for FI. If you wanted to go FI on the Ram Jet, you would at least need to change the cam, rod lengths, lower the cr (if you plan on making over 8#'s), match a cam to your heads (should be done), replace the weak cast crank, and get rid of those crappy "not good for boost" Hypereutectic pistons. The ram Jet 350 is allready built close to it's limit, and is built mainly for N/A use.
                                  yeah....... the ram jet......
                                  this is me not understanding domestic motors....
                                    lol o ya i have a four barrel carb on the lude
                                      Ok, I this has been asked in chat by a couple of people already but here is my opinion on two of the best mechanics I know. The first is a guy named Jerry Ericson, he lives in Fargo (or moorhead, I forget where he told me he lived....) he was trained/employed by one of the best engine builders I know (Dick Schulz, more on that later) prior to moving to Fargo. He has all sorts of experience building high performance street/strip V8's. I forget which shop he works for in Moorhead but will try and find out soon. His home number should be in the phone book so I'd try giving him a call if you are serious about having V8 work done.
                                      The second individual is Dick Schulz. By far the best mechanic I have ever met personally. He operates Schulz Engine & Machine in Harvey, ND. Dick has been around racing and v8's his entire life and builds many of the race engines for both dirt oval track and straight line in Western ND. Much of what he does is based on his own experiences in racing. Those of you who follow circle track dirt racing might be familiar w/ his nickname "Grandpa Dick Schulz." He is a super nice guy that has probably forgotten more about building SBC's than the rest of us will ever know. If a trip to harvey (~200 miles) doesn't bother you, I'd STRONGLY recommend his services. Or give him a call @ (701) 324-2573, I'm sure he'd be able to help you w/ any questions you might have.
                                      • RaiderR Offline
                                        RaiderR Offline
                                        Raider
                                        Daveh I sent you a pm
                                        POWERD BY
                                          I'd also recommend Brian at Sturdevants on Main Ave. He runs the machine shop there and also does assembly.
