  4. Dave, Matt, Bill
Dave, Matt, Bill
53 Posts 17 Posters 5.4k Views
    What sort of fuel pumps are each of you running currently?
    Have you had problems with and would advise to stay away from types?
    Thought one of you had problems with an A1000 and I have heard problems about those?
    thank you
    • 63vette6 Offline
      63vette6 Offline
      63vette
      thank you
      I believe Bill will be selling his soon if you need one.
      • fallguyF Offline
        fallguyF Offline
        fallguy
        thank you
        Dave and me are using a Weldon 2345.
        I used an A1000 before, and that bit the dust. I also used the Aeromotive Pro series pump before the Weldon.
        1990 Ford Probe GT 2jz RWD
          How loud are the Weldon pumps? is the pump like you have good for continuous use or no?
          I picked up a Magnafuel 4301
          Any of you heard good or bad about these pumps?
          • 63vette6 Offline
            63vette6 Offline
            63vette
            They make good pumps.
            • XJHEADX Offline
              XJHEADX Offline
              I have a Weldon 2035. Pressure started dropping at about 1250 rwhp at the track. I added my old Accel DFI pump that I used on the Cobra. It flows about the same as the 2035. They aren't too bad if mounted properly. Here is the video of the Weldon that was bolted right to the car with no isolators.
              [ame]http://www.youtube.com/watch?v=8Qc07FKciTc[/ame]
              If I can make room I am going belt drive this winter.. I don't like the idea of two pumps.
                good to hear
                sheez, just makes a little bit of noise 😉
                hope the magnafuel doesn't make quite that much
                are the weldon pumps user rebuildable?
                what is your used weldon pump worth?
                thanks
                  Silly electronic fuel pumps...
                    The 2345's are rated continuous duty but the 2035 isn't. Weldon makes a fuel pump controller so you can use it for continuous use thought. You can hear the 2345 in this startup vid at 0:19.
                    [ame]http://www.youtube.com/watch?v=0ZHP3XkoO4Y[/ame]
                    • XJHEADX Offline
                      XJHEADX Offline
                      thanks
                      A new 2035 is about $850, Dave's pump is over $1000.
                      Guys are getting around $500 for a used 2035.
                      Weldon FAQ says send in for repairs. I have not heard of too many issues with them unlike the A-1000. I was running the A-1000 in my N/A set-up with no issues. I think it is on Christian's car right now.
                        ok, thanks
                          aliengotpsi
                          I have 2- 255hp walbo intank fuel pumps.. should be good for 700 or more.
                          Kevin Smith
                          Straightlinedetailing.com
                            screw walbro pumps and/or using two pumps
                            if i was going to use two pumps it would be bosch 044's
                            044>>>walbro 255
                              yeah then one shits under full power and bye bye engine
                              Id rather have just one pump quit and loose fuel altogether than have one pump out of the two quit and let the engine still be running in possible serious lean condition
                                and how big of line are you guys running from the pump forward?
                                • 63vette6 Offline
                                  63vette6 Offline
                                  63vette
                                    63vette;297007 wrote:
                                    that takes more power to operate than my engine makes... lol
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      I was running a -8 N/A and spray. Now a -10
                                        -10 AN here also.
                                          DaveH;297058 wrote:
                                          -10 AN here also.
                                          lol that means -8 for me,
                                          what regulators for you guys, and do you have a filter pre and post pump?
                                          I should have just named this thread ..."the really fast guys' fuel systems" haha
                                          thanks
