  4. Anyone know a good mechanic shop?
46 Posts 20 Posters 1.6k Views
    slowica;298612 wrote:
    give me the year and i can run a quick check on alldata for you, see if theres any tsbs on it.
    1997
      bubba;298628 wrote:
      umm... no 3.8 was a great motor.. 3.1 = nasty piston slap
      umm....the 60 degree V6s were very successful motors for GM...they hardly ever had problems(with the exception of the 3.4 DOHC). GMs problem has never been engines, its FWD trannies.
      • SlowicaS Offline
        SlowicaS Offline
        Slowica
        apparently my hint of sarcasm wasn't noticed lol
        • harmH Offline
          harmH Offline
          harm
          integra_gsr98;298598 wrote:
          You have obviously never installed remote starters for a living then... It takes a resistor and a relay and is not rocket science.
          no, I definitely haven't. I'm not trying to say it's difficult. I just haven't seen many people do it right. I've fixed plenty of home-brewed attempts at soldering in resistors, wired-in keys.. just saying if he can still crank the engine over, the problem isn't VATS-related.
            I seemed to have fixed the car now. I changed the fuel filter which was nasty. Then last night I checked for spark and it was getting it. I pulled one plug and it was ok, but it was showing signs of wear. I pulled out another spark plug close to the oil fill cap and I found a pile of oil. the Plug was toast. So i pulled the next plug and it was even worse. When I had the oil changed the lube tech must have spilt oil into the spark plug hole. I replaced the front three plugs for now since i have to remove the intake mainifold to get to the rears.
            Anyways i went to start the car and still wouldnt start. It was still flooded. I finally got it started and it smoked to beat hell for 5 mins. It seems fine now, so later today I am replaceing the rest of the plugs and all the wires. Gayness
              Keep an eye on the spark plug wells, it could be a valve cover gasket.
                Pretty sure you can do the rear plugs with out pulling the intake manifold.
                • gsrEKG Offline
                  gsrEKG Offline
                  gsrEK
                  not on the engine thats in the car, its a 3.4 DOHC. IIRC
                  2009 Yamaha Zuma 125, gas HOG
                  2008 Honda Fit daily
                  A s2k
                  1991 Honda civic DX Mint SOLD
                  1988 Mitsubishi Mighty max
                  > BlackEJ8;233529 wrote:
                  • SlowicaS Offline
                    SlowicaS Offline
                    Slowica
                    did plugs on one last year. what a fun time.
                      Yup!
                      We pulled the front engine mount and used a ratchet strap to rotate/tilt the motor forward.
                        have u listened to some of the lumina, cutlasses, etc.... sure it runs fine but sounds like crap...
                          Yep, I owned one lol sounded like a diesel in the winter and cold mornings.
                            99.9% of the cars on this board sound like crap...
                              yeah started to do the rear plugs today lost all ambition.
                                qft....
