  4. finally more turbo for the diesel
44 Posts 13 Posters 4.4k Views
  • K
    K
    King Ricer;298713 wrote:
    want a cookie?
    yup! come bring it to me!
    • zbrownZ
      zbrownZ
      KA-T_240;298705 wrote:
      I just saw a BD Super B going on a Cummins today....
      The "super B" is a 57mm comp, and a 65mm turbine
      The "super B special" is a 64.5mm comp, and a 71mm turbine... which is what i have
      was it on a 3rd gen truck?? cuz even just the super B would be a huge upgrade over the 9cm hotside on the stock turbo, that thing is big EGT maker
      • King RicerK
        King RicerK
        for you
        Trafik Jamz;299122 wrote:
        • K
          K
          Just the smaller one. Went on an 01 24v. The compressor housing looks smaller than the hx35 that came off.
          • BookemB
            BookemB
            Bookem
            Hey Zac, does that have the wastegate on it or is that the difference with the 35w? We have one wearing out, and looking for a used replacement.
            Legacy GT
            Gmc Suburban
            Hallorann: Fargostreet?
            Hallorann: No, I ain't.
            • zbrownZ
              zbrownZ
              are you asking on the original or new turbo?
              but yes both the new and old are wastegated
              old is only wastegates one volute... new does both and they are big
              • beachbum_jonB
                beachbum_jonB
                beachbum_jon
                zac, have you loaded your engine much yet? im curious how it will pull while towing
                -John Adams, 1735-1826-
                • zbrownZ
                  zbrownZ
                  no, nothing really heavy yet
                  but honestly I am amazed how it is working..... don't know why people say you dont want to pull with a 64?? unless it is that much different in a maunual truck?? I almost wish i would have went with a 66 as seeing how responsive the 64 is
                  At unloaded cruising i now see slightly higher EGT's and lower boost pressures.....(should help some with mileage from easier engine breathing). but with a little bit of load it will quickly trasition into good boost with out any smoke or hesitation.... then the EGTs stay way way lower than they would have with the stocker under any load
                  We will be hauling calves in a week or two so that will be 25k lbs.... see then what it does with a heavy load. Should get a vid showing all the guages when i am loaded like that accelerating and cruising loaded.
                  As of now i love it... and really see no absolute need for twins... I know now that i could go to a 66 if i needed more and still spool it to my liking
                  jacobs give your 2 cents, you rode in it and can attest to the spooling, EGT's, and power increase
                  Its still a tossup as to whether the 4K governor springs, torque converter change, or turbo swap made the single most impressive change all by itslef
                  • beachbum_jonB
                    beachbum_jonB
                    beachbum_jon
                    64 sucks with a manual, even with a bigger pump and chip turned up all the way. it was annoying to drive, once it spooled it was decent, but the twins are soooo much better. we pulled a 25ft enclosed car trailer with a early 80's delta 88, fridge, washer & dryer, big tv, and lots and lots and lots of heavy boxes and tools and stuff from phoenix up to flagstaff (up a mountain) and with the monster pump, ddp 150's and the twins, it pulled amazing, and beleive me, we were doing 80 the whole way up and could still accelerate quickly
                    • BookemB
                      BookemB
                      Bookem
                      Old one, looking for one used and local. Wasn't sure if that works in place of the commercial 35w though.
                      Legacy GT
                      Gmc Suburban
                      • DrifterExtremeD
                        DrifterExtremeD
                        I will kill you zac if you sell that thing.... :mad:
                        • GrrG
                          GrrG
                          if you are referring to the HX35, it was sold before the new one even showed up.....
                          • BookemB
                            BookemB
                            Bookem
                            I am looking for one, but wondered if the hx35 works in place of the hx35w, which we have one that is wearing out. Everyone tells me something different on the difference between the two, just need one that doesn't squeal when the engine is at upper rpms.
                            Legacy GT
                            Gmc Suburban
                            • K
                              K
                              What is the turbo off of? If you need a replacement turbo talk to my dad.
                              • zbrownZ
                                zbrownZ
                                well beahbum, hauled the calves and finally had it loaded heavy
                                works great for keeping my EGT's good and all that stuff in check but there is only one thing that i get that is a nuisance.
                                if i am in OD with the converter locked and i am going slower than 60 mph with a big load you cant go beyond 20psi or i get compressor surge which is gay but i can live with..... anything at or above 60mph i can go full throttle with a load
                                made a little gay vid to show what kind of response it has and how loud the compressor is at low boost especially
                                from a dead stop accelerating normally and i stab the throttle for a quick second. rolls from 15psi to 40psi like nothing
                                would be interesting to see the actual difference on a manual truck
                                you need volume, camera has had a horrible life
                                [ame]http://www.youtube.com/watch?v=vVVonGCTQU4[/ame]
