  4. My new dd/beater project
53 Posts 20 Posters 5.1k Views
  • wesholeW
    wesholeW
    Brandon, ever get the light figured out? I guarantee its the ground. If you cannot trace it, run a new one to the chassis.
    • M
      M
      me_john85
      looks pretty sweet, the RS front end is alot better
      • bubbaB
        bubbaB
        No, stensland was looking at it, and said it must be a bad wire (grounding out but not enough to blow a fuse or something) between the relay and headlight, but i didnt have time to trace it yet.. it's getting the proper voltage and everything..
        • B
          B
          Colin;291816 wrote:
          you can order through a dealer, but only if you have the part number. a dealer can't search the part for you. meaning if you walked in and asked: "order me a lightweight bemper beam" the dealer would say: "i don't show that part".
          IF you said: " order part number 32527653464"
          they would say: "ok"
          makes sense. thanks.
          • wesholeW
            wesholeW
            Brandon. I'm pretty sure it is a ground not supplying enough connection to allow full voltage. Tap a new chassis ground to each of the bulbs negative wire and verify this. It's quick and easy to do.
            • bubbaB
              bubbaB
              Bump... got fogs and stuff put in the bumper a while back, been too lazy to take pics...
              However, i'm 90% sure this project is getting scrapped..
              • 99civic9
                99civic9
                99civic
                why is this???
                2000 civic SiR - jdm sickness
                • King RicerK
                  King RicerK
                  99civic;300266 wrote:
                  why is this???
                  cause he is lazy! duh! 🙂
                  Trafik Jamz;299122 wrote:
                  • bubbaB
                    bubbaB
                    this
                    • wesholeW
                      wesholeW
                      And cuz he NEVER finishes a project.
                      • bubbaB
                        bubbaB
                        yep, putting it back to the way i bought it and selling it to the gf for cheap... crx is pending sale too... probably just buying a clean stock car...
