  4. Track Car
Track Car
181 Posts 28 Posters 10.7k Views
    zbrown;302229 wrote:
    Like thrash said though, that is the point of the typical C channel frame, allowing flex over uneven ground, to reduce chances of cracking, and to keep traction
    dont know about new dodges but the 2nd gen frames are boxed from the front to just a bit behind the firewall, C channel the rest of the way
    Well, the thing is, these tests are obviously proven to show Ford as the "best". I highly doubt these are standardized tests, but I could be wrong.
      everyone has numbers to support "built ford tough" or "chevy like a rock" or "gmc professional grade." who cares anyways. toyota makes a great GAS truck. you going to be the new eurofan of pickups now?
        Good town trucks. .. bad field trucks. .
          We should debate whether or not the Chevy/GMC pickups or Toyota pickups are better city trucks.
          • capitljC Offline
            capitljC Offline
            capitlj
            zbrown;302058 wrote:
            so can we all friends if we clarify that it is not Hondas that suck, but rather FWD in general...
            Yes.
            > Mitch Hedberg wrote:
            2004 Impala LS 3.8
            • W Offline
              W Offline
              WannabeG
              YellowEvo;302221 wrote:
              My Toyota is doing just fine, how often do you actually drive on something like that you stupid fuck? And ask me again why my Tundra can pull my camper no problems up hills and my brothers Ford had to pull over and sit for a bit cause it got a little tired :icon_scratch:
              Toyota tough gets all butt hurt when i call his truck out. I did it because your probably some JDM butt humper that bought that crappy pickup because its a 'toyota'. And those tests show a lot. When you have a heavy load on your truck, a flexible frame is something you do NOT want. Maybe if you drive around town with some plywood in if the bed, its fine, but for anyone that actually uses a truck for what its designed to do, that won't cut it.
              Figured i'd exchange the shit and put it on somebody else for a change. :icon_santa: and BTW, i don't drive a Ford. Never have, never will, but they know how to build a fullsize truck 30X better than Toyota. Its not a very good truck, but its better than a Ridgeline lol.
              Ridgelines are gay. :icon_rr: Honda building a truck.... ROFLMAO
              2008 Infiniti G35S Sedan 6MT
                I don't think that yellow evo would use his truck for hardcore offroading or for a farm truck, at least that's how he comes across, lol.... So why the hell would it matter if his truck can go through that kind abuse...
                • W Offline
                  W Offline
                  WannabeG
                  His truck is Mall Rated.
                  • KossickK Offline
                    KossickK Offline
                    Kossick
                    yeah considering that Joe has owned 4 trucks before this one, he had a F150, a silverado, and 2 duramax's. And btw i just wanna make sure i have this right.... if you're not constantly hauling around the heaviest load possible then you're not using the truck for what its "designed" for???:icon_salut:
                    2012 Volkswagen CC Lux Plus
                      Trafik Jamz
                      I had a Tundra that did experience the "bed bounce" in one spot on the road (by hillsboro heading south) but ONLY when traveling at ~63 to 67 mph. Yes, it was a resonance issue, but all you had to do was speed up above 67 or slow down below 62 to overcome it....and even then only at certain times/pavement types/expansion joint spacings did it ever occur. FWIW, my Tundra would out-pull my dads F150 with EASE when pulling a loaded stock trailer. IF I were to buy another new 1/2 ton, Toyota would still be high on my list....especially if it were for pulling a trailer of some sort.
                      701.541.3484
                      • YellowEvoY Offline
                        YellowEvoY Offline
                        YellowEvo
                        I carry carpet/vinyl and tools in the truck... Does just fine for what I need it to, I'll take the ride of my Tundra over any of the others I have owned, and as for pulling I already told you that it pulls my camper with no problem where as my brother took it and he had to pull over and sit for a bit cause the Ford was having troubles. I took my truck to the cities doing between 80-85 and experienced none of the bed bouncing, although I have felt it before but nothing to the significance of me wanting to get rid of it. Only thing I would switch about it is the way you have to turn off the VSC I believe where everytime you turn on the truck if you dont want it on you gotta hold a button for 3 seconds, there's a mod I saw for it to take it off but I am not confident enough with doing it myself. And no I dont hump JDM because this is my first Toyota, I've had my share of American cars and Imports whichever you choose as I ''hump" away.
                        2003 Mitsubishi Evolution 8
                        2011 Ford F150 Ecoboost
                          Trafik Jamz;302478 wrote:
                          1/2 ton, .
                          bingo.
                            YellowEvoY Offline
                            YellowEvo
                            Touche, but I have no problem getting dirty... Gotta love pulling out carpet and pad that is stained by cat piss :icon_rr:
                              yummy...
                              • W Offline
                                W Offline
                                WannabeG
                                Well whatever works for you. I'll stick to my 6.0 with 370wheel horse (tuned her up a bit 😉 ) Dont even feel the boat anymore!
                                (i love pickups, if i lived in Fargo year round, my car would have been sold last august)
                                  Doesn't take much...my boat doesn't pull hard behind my fulltime 4WD Durango. Camper>Boat
                                  • W Offline
                                    W Offline
                                    WannabeG
                                    Our boat is 22ft long. We also tow a gooseneck horse trailer and cars on quite a few occasions.
                                      lulz. this.
                                        Silly city folk....
                                        • W Offline
                                          W Offline
                                          WannabeG
                                          I love how this went from track cars, to pickup trucks and SUVs and what we tow...LOL all thanks to me!
