  4. Flood 2010 Pictures
Flood 2010 Pictures
41 Posts 15 Posters 3.9k Views
  • XJHEADX Offline
    XJHEADX Offline
    The ginder station alarms are going off like crazy out there. Almost everyhouse has one.. Not good.
    • RaiderR Offline
      RaiderR Offline
      Raider
      what is a ginder station alarm? sorry never heard of it
      nevermind googled it
      POWERD BY
      • dubbsyD Offline
        dubbsyD Offline
        XJHEAD;303370 wrote:
        Heritage Hills South of Fargo, 88th ave.
        I thought that's what that looked like. I thought they were bought out?
        So that's at only 31'. wow. When I drove through out there last summer I thought it looked like the river was further down than that.
        • XJHEADX Offline
          XJHEADX Offline
          That is what the river is under normal conditions.
          All the homes originally had septic systems. After the sewer came through they connected the line to a small lift station to a force-main. Most of the manholes are under water and are taking on too much water so the pumps won't keep up.
          Blue is the 1st picture facing West
          Maroon is the 5th pict facing North
          Red is the last picture facing North
              thrash
              Can you tell me a little bit more about your house-sized fort? I don't want to go to your blog. I'm just wondering what the rationale is here. Does this stay up year round from now on? What makes a water-tight seal here?
                He builds it every year and takes it down after the flood.
                  We take it apart in sections and store it...
                  there is 6mm plastic wrapped over the top of the wall and held down to the ground by sandbags...
                  • XJHEADX Offline
                    XJHEADX Offline
                    Joel;303434 wrote:
                    there is 6mm plastic wrapped over the top ...
                    That's some THICK stuff.:icon_rabbit:
                      We wouldnt find any 4 or 5mm that was 20x100
                      • XJHEADX Offline
                        XJHEADX Offline
                        :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit: :icon_rabbit:
                        • kylushK Offline
                          kylushK Offline
                          kylush
                          lol
                          1998 Z28 Camaro
                            This is the concept behind the plastic that is on the ground in front of the wall... My idea last year after we had a blow out... does anyone think it actually does anything?
                            • XJHEADX Offline
                              XJHEADX Offline
                              It will help at your joints on the plywood and help keep them dry. The real deal with the plastic is erosion from the moving water on a clay dike. If you had a blow-out it was from lack of bracing. You guys still need a lot if the water comes up more than 3' on the plywood. Look at some pictures of plywood concrete forms and you will see what I was talking about.
                              ps. I did stop by and someone didn't want any advice today. Lunch was more important at the time.:icon_scratch:
                                XJHEAD;303443 wrote:
                                It will help at your joints on the plywood and help keep them dry. The real deal with the plastic is errosion from the moving water on a clay dike.
                                6 mil... lol i guess i never really though about 6 mil not meaning 6mm... anyways...
                                Do you think it is helping with any of the water pressure? I realize it is helping with erosion now that you say that.
                                • XJHEADX Offline
                                  XJHEADX Offline
                                  Use it if you haven't in the past and the seams were leaking. It won't do a thing for the pressures.
                                    I dont think that the plastic draped over a wood wall is going to help with pressure, but I am not an expert.
                                    • XJHEADX Offline
                                      XJHEADX Offline
                                      the horizontals are the walers
                                        Seams weren't leaking, just had a large blowout in front of the wall and the water spewed out inside the dike. It almost took us out last year. we piled a shit load of bags on it and slowed it down enough for it to freeze(thank god it was like 10 degrees outside that night)
                                          No, the plastic on the ground protruding from the wall... We were trying to stop the downward force of the water and preventing water from taking out the ground below the wall/planter
