  4. MPFI swap: No ecu or fuel pump power
15 Posts 8 Posters 1.9k Views
    Cut the engine harness
    • blackcherryTSiB Offline
      blackcherryTSi
      thurmanmerman;308670 wrote:
      Was working out problems with a couple codes that my ecu was throwing and took it for a test drive. Ended up dieing completely out of no where. Checked the main relay, grounds and fuses. Cannot figure out whats going on. Ive looked into the wiring and that seems to have checked out fine. Are there any other fuses not in the engine bay box or under the dash that would cause this problem?
      look where the car came from lol
      1995 Honda Civic
      • thurmanmermanT Offline
        thurmanmerman
        Slowica;308681 wrote:
        getting power everywhere else in the car?Yep. Everything else turns on. Starter cranks over just no power to the ecu or fuel pump
        SPANISH-RICE;308691 wrote:
        Cut the engine harnessNah, already checked the main relay and its still good so its not a candidate for getting chopped in half yet. 😛
        blackcherryTSi;308694 wrote:
        look where the car came from lolDidn't you buy a car from the same person? :icon_scratch: lol
          blackcherryTSi
          nope. never have never will ha
          1995 Honda Civic
          • gsrEKG Offline
            gsrEKG Offline
            gsrEK
            cut in half!!
            2009 Yamaha Zuma 125, gas HOG
            2008 Honda Fit daily
            A s2k
            1991 Honda civic DX Mint SOLD
            1988 Mitsubishi Mighty max
              thurmanmerman
              For real. I need to get this figured out.
                Get your multimeter out. Make sure all of the wires that should have power have power, if the wires are good all the way to the ECU plug, maybe the ECU popped??
                  what ecu is even in there...
                    thurmanmerman
                    PM6
                      blackcherryTSi
                      thurmanmerman;308784 wrote:
                      PM6
                      sure about that?
                      1995 Honda Civic
                        blackcherryTSi;308789 wrote:
                        sure about that?
                        lol
                        • harmH Offline
                          harmH Offline
                          harm
                          sounds a lot like when my ecu suspiciously blew - for no reason on the day the landlord kicked the neighbors out..
                          starter cranked away, no power to the fuel pump, checked the main relay, fine, checked for a code at the ecu.. no power no nothing.
                          put in a new one, fixt.
                          btw does anybody want a pr4.. cheap..?
                            thurmanmerman
                            sure about that?
                            Unless he went stealthmode on it and put PM5 guts in a PM6 case. Its a PM6.
                            Got it to start last night but only after jumping the main relay with 12v power. Fuel pump primes and ecu comes on.
