  4. Got a question with my aftermarket radio(Jensen VM9311TS)
16 Posts 8 Posters 1.9k Views
  • wishinskyW
    wishinskyW
    wishinsky
    hmm it's in my mustang and i think i figured out the problem....Thanks chuck haha when you said a short blown fuse it clicked in my head...There is suppose to be a yellow wire which is for the battier which has a black box and a fuse on it... When i got the wire harness the yellow wire was pulled off and i never got it. So i just so solder a wire in the place. I bet because it doesn't have that fuse in there its not working?
    -Cars i drive
    2002 Mustang
    1997 Bravada Smart Track
    • Toys
      05 TTR 125 L/LE
      02 YZ 85 with 110cc kit
    • PSiedTSiP
      PSiedTSiP
      A fuse is nothing more than a wire as a fail safe that burns up if the current capacity is reached, so no. A regular wire works in place of any fuse, but obviously thats not recommended because it gives no protection.
      spanish-rice;237125 wrote:
      • T
        T
        Trafik Jamz
        I said a short in the system or a blown speaker....bypassing a fuse won't cause those issues that you mentioned...at least not directly.
        701.541.3484
        • wishinskyW
          wishinskyW
          wishinsky
          Hmm i see. Well this sucks. Haha
          -Cars i drive
          2002 Mustang
          • Toys
            05 TTR 125 L/LE
          • MisterCMKM
            MisterCMKM
            You need to disconnect the field wiring and verify that the deck itself is working normally. Figure out if your problem is the car or the deck.
            thrash;315544 wrote:
            Ford is back :)
            • wishinskyW
              wishinskyW
              wishinsky
              i hooked up my other cd player back up and it works great... Um ok well this will probably hit the nail on the head. (When i soldered the wire on my dad was helping me and the solder connected the Yellow Battier wire and the ground wire and it sparked when i first connect it all up and blew my radio fuse for the car. I replaced the fuse and resoldered the wire..I am guessing i screwed the radio up)
              -Cars i drive
              2002 Mustang
              • Toys
                05 TTR 125 L/LE
              • 2
                2
                2loud
                Correct me if I'm wrong, but it sounds like you shorted it out by hooking power to ground...unless I misread it.
                • DelSlowD
                  DelSlowD
                  Uh yeah...
                  • wishinskyW
                    wishinskyW
                    wishinsky
                    any way to get it fixed? Any of you know some one or a place that does shit like that?
                    -Cars i drive
                    2002 Mustang
                    • Toys
                      05 TTR 125 L/LE
                    • PSiedTSiP
                      PSiedTSiP
                      Isn't that like a $50 player? http://fargo.craigslist.org
                      • wishinskyW
                        wishinskyW
                        wishinsky
                        idk...Why do u want to buy it for 50 bucks? haha
                        -Cars i drive
                        2002 Mustang
                        • Toys
                          05 TTR 125 L/LE
                        • GoodnbuzzdG
                          GoodnbuzzdG
                          Goodnbuzzd
                          Sounds like a toasty radio. (after the short). Once you release the genie outta the bottle, you cant put it back! Better buy another radio and try again, this time without shorting it. 😄
                          • wishinskyW
                            wishinskyW
                            wishinsky
                            haha for sure...
                            -Cars i drive
                            2002 Mustang
                            • Toys
                              05 TTR 125 L/LE
