  4. noisy acceleration
noisy acceleration
23 Posts 11 Posters 3.7k Views
  • inspector01I
    inspector01I
    Any CELs?? Any change in top end power?? Check the cat if you have one.
    • theobliviousT
      theobliviousT
      theoblivious
      no CEL and how can i check the cat? do i need to physically take it off the exhaust?
      BOOST....to be continued
      • theobliviousT
        theobliviousT
        theoblivious
        bump
        • Bp-08B
          Bp-08B
          Bp-08
          sounds like your muffler bearing is shot, id look into that.
          • JoelJ
            JoelJ
            yes ken youll haveto take it offf the exhaust
            • darkelvisD
              darkelvisD
              darkelvis
              no joel you fucking dont
              • SheeranS
                SheeranS
                Sheeran
                you can get the exhaust up to temp by cruising for a while and get out with your motor running and check to see if the pipe before the cat is glowwing (best done at night) and if it is then your cat may be clogged. another test is you can drill a hole in the exhaust before the cat and see if it runs better and if so mmost likely a clogged cat and get it changed and the hole welded shut.
                • SPANISH-RICES
                  SPANISH-RICES
                  sheeran;316889 wrote:
                  you can get the exhaust up to temp by cruising for a while and get out with your motor running and check to see if the pipe before the cat is glowwing (best done at night) and if it is then your cat may be clogged. Another test is you can drill a hole in the exhaust before the cat and see if it runs better and if so mmost likely a clogged cat and get it changed and the hole welded shut.
                  my god, stop drilling holes in shit or removing exhaust. Unscrew your precat o2 sensor and install a backpressure gauge. There is almost alwyas a factory spec for this. Please tell me you dont actually drill holes in shit your trying to diagnose???
                  If you had a bad cat youd more than likely throw a check engine light. Have you ever adjusted the valves on this car? Change where youve been getting your gas lately?
                  • SheeranS
                    SheeranS
                    Sheeran
                    i havn't personally done it but i've heard of people doing it with success. It would be alot easier than pulling the o2 IMO. I've never had luck with those comming out very easily.
                    • darkelvisD
                      darkelvisD
                      darkelvis
                      holy fuck...someone finally posted something that isn't fucking dumb!!!
                      • K
                        K
                        I have never had a issue taking 02 sensors out. Its all about having right tools.
                        • SlowicaS
                          SlowicaS
                          Slowica
                          you have to remember what a lot of people have for tools
                          • SlowicaS
                            SlowicaS
                            Slowica
                            either way, the description of whats wrong is far to vague to give any kind of proper diagnosis. what kind of noise does the car make.
                            • SheeranS
                              SheeranS
                              Sheeran
                              an impact wrench and o2 sockets aren't proper equipment? it was as stuborn as some of the people on here. Tried everything and we finally used a torch and got it out. Took about 2 hours just to pull the original and maybe 30 seconds to screw in the new one LOL
                              • theobliviousT
                                theobliviousT
                                theoblivious
                                thanks for the replies, as far as the backpressure gauge, im not exactly sure where or what i need. The car has roughly 160k on it...could it just be the cat?
                                Ill check tonight if the catalytic converter is glowing after running it for a while tonight
                                • SPANISH-RICES
                                  SPANISH-RICES
                                  Some people shouldnt be working on cars...
                                  • SheeranS
                                    SheeranS
                                    Sheeran
                                    some people should remember back to when they first got into cars and quit saying things about others that applied to them at one point. Everyone has to start somewhere and not everyones parents were into cars so they weren't able to get the headstart at the age of 5. Most people have to wait untill they get a car of their own to start working and learning.
                                    • PSiedTSiP
                                      PSiedTSiP
                                      There is a simple solution for that....don't give advice. Just listen.
                                      spanish-rice;237125 wrote:
                                      • SlowicaS
                                        SlowicaS
                                        Slowica
                                        Even when you think you know almost all there is to know about cars, you don't. Being in the field you learn that pretty early on.
                                        • SPANISH-RICES
                                          SPANISH-RICES
                                          psiedtsi;317017 wrote:
                                          there is a simple solution for that....<u>don't give advice. Just listen</u>.
                                          exactly
