  4. Motor Carnage (Pics inside)
11 Posts 6 Posters 1.9k Views
    Just wondering if anyone could tell me/ Guess why this happened...
    Car- 2001 Ford Focus SE Single Cam
    Problem- Parked the car one day. Started it the next day, loud knocking coming from the motor, had to hold the accelerator halfway to the floor to keep it running. I let it die. after trying toi diagnose it for another 30 seconds or so of keeping it running, it seized. f
    I opened the motor up today in the middle of swapping it, to reveal this...
    Pieces of piston skirts in the oil pan
    Small Dents in the Piston
    Matching dents in the head...
    Weird things...Valves are fine and fully intact, No Metal between head and piston, no visible damage to top of piston and the crank turns freely now that the heads off, and all pistons still move with the crank.
    • SheeranS Offline
      SheeranS Offline
      Sheeran
      how many miles were on it???
      • Top EndT Offline
        Top EndT Offline
        Top End
        Were are the dents in the pistons that your refering to?
        So you started the car, motor knocked so you held the it at half throttle to make it run and forced it to run until it seized...?
        ***Top End Dragways
        ***http://www.topenddragways.com
          yep... motor is shot anyways once it started knocking, from the way it sounded... fyi i said thirty seconds but it was more like 5 or 10 seconds.
          • Top EndT Offline
            Top EndT Offline
            Top End
            My guess would be spun bearing/s
            THat is sort of true, a few knocks from a spun bearing may only need new rod/s bearings and some machine work. Seized motor usually takes a bit more.
            ***Top End Dragways
            • BookemB Offline
              BookemB Offline
              Bookem
              Did she let it idle for a really long time warming up in the days prior to the carnage? Or started it up cold and took off right away driving at highway speeds?
              Legacy GT
              Gmc Suburban
              Hallorann: Fargostreet?
              Hallorann: No, I ain't.
                It wasnt cold when this happened...
                • Top EndT Offline
                  Top EndT Offline
                  Top End
                  Have you torn any farther into the motor or just removed the head? Once you get a look at the the bottom end you will most likely see what happened, I'm still guessing bearings.
                  ***Top End Dragways
                    there was pieces of piston skirt in the oil pan... thats all I have gotten to so far. I think all the pistons and head wear is from detonation the more I look at it... severe detonation.
                      I was kinda waiting to see a miata motor.... lol
                      • Bp-08B Offline
                        Bp-08B Offline
                        Bp-08
                        Have you taken the pistons out yet? Sounds like either a cold seize, or a spun bearing. If the piston expands too fast before the rest of the motor, your piston to cylinder clearance will decrease, and will seize, and being you revved it up the skirt broke, because the skirt is the largest part of a piston. The marks on the top of the piston could actually be from pre ignition from pieces of the piston making its way up there.
