  4. Turboed 4g63
Turboed 4g63
51 Posts 11 Posters 2.1k Views
    or if you really want to turbo you n/a 4g63 i have 7 bolt turbo cams, rods, crank...pretty much everything from a turbo 7 bolt 4g63....the pistons are okay but they need new rings.
      straightline specialties in fargo: http://www.straightlinespecialties.com
      I'm gonna have to disagree with out there, its not really easier to get the entire 4G63 becuase it will be alot more expensive.
      The best way to do it would be to get all of the needed parts: Turbo ECU, Knock sensor, turbo injectors (450cc not the auto ones), turbo, manifold, oil lines.
      If your looking to actually make power, you'd want to look at getting different cams. The NT 9:1 pistons arent terrible, with correct tuning and that higher compression you can put out some good numbers.
      Your going to also need a fuel pump if you plan on running any amount of boost.
      Depending on what parts you can find used, it might be sort of costly to do right. There cheaper ways to do it, but if its just going to blow up whats the point?
      Might want to look in to what you can get for the car, and see if you can find a nice AWD 1G... everythings pretty cheap these days
        Um...? I thought yours blew up?
        He's already got a 7 bolt block, the same rods as you have, and the 2G head is totally different so your parts wouldn't workin his. You cant re-use those pistons anyway...
          most of those are stand-alones, stay away from them.
          any place that sells import performance parts has piggyback systems, they are usually referred to by name (safc, for example).
          you should ignore the idea of a stroker engine for a long time, you're still learning about what it takes to build a turbo engine... gotta learn to walk before you can run the boston marathon
          EDIT: jim, i meant that it might be a little easier, not cheaper 😉 and i do not believe the ecu from any turbo dsm will work unaided, due to the compression difference. otherwise i believe we're both preaching nearly the same gospel, just in different languages 😄
          • M Offline
            M Offline
            MrScary
            Ok then right now I want to do intake and exhaust. Who makes an intake and a good exhaust: header, downpipe, cat-back
              To clear up confusion from earlier in this post:
              90-94 (1st Gen) Turbo Cars: 4G63T
              90-94 (1st Gen) Non Turbo: 4G63
              95-99 (2nd Gen) Non Turbo: Chrysler 420a
              95-99 (2nd Gen) Turbo: 4G63
                Don't waste your money, you won't notice any significant gains. You'll be hard pressed to find NA aftermarket for 4G63 becuase nobody bothers...
                Save your money for a turbo setup, or a turbo car if you want to modify a DSM its the only way
                  i don't know man... the dude from dsmtuners with 125whp from an all-motor 1.8? you telling me that's not a good way to go? :eek:
                  I'm kidding, you don't want to know how much he spent on that car!!
                    it didnt blow up....the was nothing blown in it....i tore the motor completely apart...and there was nothing broken....so im not really sure what went wrong...and how cant you re-use pistons?
                      Haha ok, try using used pistons !
                      BTW: New .020 over 2G Pistons are $140 shipped
                        i have used used pistons before...and that engine still runs.
                          i would recommend using the 2g pistons for turboing the na 4g63, it would make using the ecu (95+) easier... but raise the cost
                            out there, i think you really are out there on this one. 2G piston is gonna be a better choice then the NA piston as well as the 1G turbo piston. The 2G piston is a 8.5:1 CR ration and definatly a better casting then the 1G piston and the NA piston.
                            JUST BUY A DAMN TSI/GSX ALREADY.
                              that's what i said, i know the 2g pistons are better than 1g, though i can't claim to know anything about the na ones
                                i have to agree with the last thing nick said, just buy a turbo all wheel drive one !
                                • M Offline
                                  M Offline
                                  MrScary
                                  What is the zip code up there??? I'm gonna search for a Tsi/GSX
                                    58103, 58102
                                    look around on http://www.dsmtuners.com/classifieds/ and http://www.gopartstrader.com/cgi-bin/suite/classifieds/classifieds.cgi
                                      or just buy mine.
                                      • M Offline
                                        M Offline
                                        MrScary
                                        How much?
                                          how much you willing to spend? oh and its a 97 gsx.
