New Stuff
Gutless;319733 wrote:
Are you using a stock ECU to control it or something like a megasquirt or FAST?sorry didn't see this, it is the stock system with HP tuners and a custom 2 bar SD OS
weshole;319865 wrote:
i want to see this run.I wish the snow would go away as i am guessing you do too, haha
kylush;319850 wrote:
Badassednessthanks, still need to start on yours!
Rexwagon;319867 wrote:
looks slowit is, 14's or bust
This thing is gonna pwn this year. Nice work.
got some pics of the cage, I guess i have never done any cage work ever, but i like the way this turned out
I can't believe what a cage will do to the chassis, I have always heard it stiffens them up but i can't believe how much
i can jack on one front corner now and three corners come up very easily, never was like that before
DOM material, SW kit that i worked over to my liking
thanks man!
made a super special bracket for the BC, haha
did cause I can't get to it like before with the compressor clocked like this now
Hallman must have a ridiculous anodizing system..... i welded it on there and it didn't discolor anywhere, usually anodizing has always discolored in the near area of welding for me
couple pics i took while zac was welding his ic piping
Grr;320017 wrote:
you havent gotten that saturn done yet??nope i lazy, but look like a stud! haha
took it out the first time the other day since i have an appointment at the body shop to get some stuff done
all i can say is it is a totally different car, the new heads, turbo, converter, trans, and intercooler really did something
on base spring pressure of 4.5psi right now it would shit on what it was like last year on 8psi
LOVE the converter and powerglide too, great combo in the light car with boost
ok have a few projects because it is supposed to snow again
hood dampers
add another muffler
sump the tank
add an electric cutout in the front fenderFirst i bought the cheap ebay set of dampers....... didn't like how they worked; they didn't open the hood nearly enough for my liking, and they made the hood bow at the rear because of where the gas spring pressure was being applied
So went to my hook up and John Deere and got a couple the length i wanted with the force i wanted
i changed where the little brackets mounted and TIG'd them to the hood arm so they didn't move all gay like
turned out great, can't believe i finally got it done........ i got rid of the stops on the hinges so that it opens WAY up now
next is a tank sump
I don't know who undercoated this car but it is ridiculous, stuff is so thick it makes a mess taking it off anywhere
shot some bedliner stuff on there when i was done, not done with redoing the pump mounting and plumbing
next is a muffler, adding another 14" magnaflow upstream of my current one, doing this to make it even more quiet
I just like going from sounding like nothing to pist off when the gates open
and last is a cutout right off the turbo to the front fender..... working on that
this is my favorite thread on fargostreet... you have some great ideas and do awesome work. i need to get your workspace setup/tools. Bay looks good cant wait to see it in person/run!
63vette;320531 wrote:
Hope you sealed the tank after welding on it. If not I am betting it already has rust in it.This. We didn't do that to my integra tank after we sumped it and it ate two aeromotive pumps.
blackcherryTSi;320518 wrote:
this is my favorite thread on fargostreet... you have some great ideas and do awesome work. i need to get your workspace setup/tools. Bay looks good cant wait to see it in person/run!Thanks!
the thing on the trailer is a big dune buggy thing of my uncles that i am fixing, and yes it does look like fun!
haven't lined the tank yet, will when my stuff gets here
i steamed it out again after i was done welding and i looked into it today and there is no rust anywhere yet so i should be fine
did some more today
here is the start to the cutout
I plan to go from that Vband the rest of the way down to the cutout and out the fender with aluminum
will 16 gauge be fine or will i need something like 11? anyone?
and then did the pump mount, you can see in the one pic where the second muffler went
zbrown;320516 wrote:
i got rid of the stops on the hinges so that it opens WAY up nowdont forget to latch it.............
