  4. Internet options....
11 Posts 9 Posters 3.5k Views
  • FG2F Offline
    FG2F Offline
    FG2
    The shop is located in a fairly small section of town that doesn't have any type of access to any quick wired internet connection. We have used Integra Telecom, and currently IdeaOne, both with poor results. Is there any type of newer service available in the area? Our current plan is 256k, but for the past while it truly is in the neighborhood of 26k-128k...yes really. I don't need Midco speeds, but I need something that can allow for us to work more efficiently.
    There is no cable, and as it sits right now, none of the major players in the area have interest in running cable/copper/fiber optics/etc to our location...
    Options?
      do you fall within the reach of multiband's wireless that they provide?
      http://www.multiband.us/home/consumerSurfWireless.asp
      I would think that you would.
        Trafik Jamz
        Man, I'm sorry that the speeds are so shitty for you over there man, I was really hoping what we provided would have worked for you (when I was at IdeaOne). Try calling Marty @ Ideaone 701.361.0534 and explain the situation if you haven't already....if he isn't any help try Christel Fritz or Mike Mack @ Ideaone. I can't imagine that you are the only ones complaining...I'd think everyone from Crystal Piers Marine on down the block would be demanding faster service.
        All of the DSL providers using the same lines in your area of town (all Qwest lines) and I don't foresee most of them crossing the road. Maybe Qwest would, but I wouldn't count on it.
        Or maybe Hughesnet satellite?
        http://business.hughesnet.com/explore-our-services/business-internet/business-internet-high-speed/connect-service-plans
        or WildBlue maybe? http://www.mybluedish.com/speeds-and-pricing/
        701.541.3484
        • BookemB Offline
          BookemB Offline
          Bookem
          We have Dakota Carrier Network at our offices, seems pretty good but we need to upgrade servers. I believe General Equipment just down the road from you guys still have them as well (might want to check with Sarah there, she'd know the best).
          http://www.dakotacarrier.com/services/view.asp?ID=3
          Legacy GT
          Gmc Suburban
          Hallorann: Fargostreet?
          Hallorann: No, I ain't.
          • dubbsyD Offline
            dubbsyD Offline
            Well, it's still not horribly fast but it's an option?
            http://www.i29.net/wimax/coverage-map/
            I think the goals are still to expand the 1.5m and 3m services but no idea when.
            Or, Verizon hotspot?
              What kind of budget do you have available for internet service Jason?
                Sat has a 5gb datacap per month.
                http://www.virginmobileusa.com/mobile-broadband/
                Check that out... you'll have better (much better) then 256k with that... >1mbps. Uses Sprint's 3G Network. You should be able to pick this up at any Radioshack.
                • FG2F Offline
                  FG2F Offline
                  FG2
                  I have spoke with IdeaOne on many occasions about this, and today they said they are going to stop into the surrounding businesses and see if anyone else would want faster service. They had some 3 letter abbreviation that they were going to do, which basically would evaluate the cost vs. return on their end to put new cable in the ground....
                  Thanks, I will look into this!
                  I will look into this as well!
                  I'm not certain Nick.... I guess I would have to look at what we have now, and compare to what we could have. The current service drops constantly, and at optimum speed is very difficult to load any page with flash in an acceptable time frame. I am not hating on IdeaOne, just hate the fact that my options are limited to such ancient service.
                  I will research this more tomorrow as well.
                  Thank you all for the help, I have a few options to look into and will hopefully be able to come up with a new plan. I think 3mbps would be more than plenty...hell 1mbps would be great....
                    I29 sucks. The speeds have gotten worse by the month. Do not go with I29!
                      Coming from Midco in Moorhead, I knew I would be disappointed moving into fargo. We ended up going with 702 Communications DSL and honestly I have no complaints. Its WAY better than I expected. Don't know where their coverage area is, but its way better than the DSL I have had in the past.
                        Trafik Jamz
                        I can answer this one with absolute certainty....they use the Qwest lines everywhere in Fargo. AFAIK IdeaOne is the only DSL based ISP that has it's own lines (copper & fiber) buried in Fargo.....unless Integra has gotten into the game now (there was talk a while back about it, but I'm uncertain as I'm out of that game now)
                        EDIT: Also, I believe Cableone has upped their speeds in fargo as well, I know that Stephen Bradley has 50mbps service at his house in S Fargo now.
                        701.541.3484
