  4. 92 Honda Accord-Vibration Problems
8 Posts 7 Posters 1.1k Views
    So I sold my truck and bought an old accord we took in on trade, and its awesome except for the fact that it has a very bad vibration at Idle. It seems like everytime you put a load on it with an accessory, it vibrates. If you and stopped in park or drive, and you turn the wheel all the way to lock, vibrations are crazy. If you are stopped in park or drive, and you turn on the air, it vibrates(not quites as bad. Without tearing into it too much, anyone know what this could be signs of? The only thing I was thinking of was a motor mount, but I am probably way off. Car is 92 Accord auto, every option.
      Did you check the Vtak fluid?
      • QuadaQ Offline
        QuadaQ Offline
        Quada
        My amateur opinion would also be a cracked motor mount. If you pop the hood, you should be able to inspect them.
          is it dropping a cylinder at idle?
          i had that awhile back this summer where i had a corroded connection at an injector and at the low pulse widths of idle the one injector would cut out
            Motor mount gets my vote as well.
              All 4 are going at idle. It also shakes really hard when it shifts so im guessing the granny mount. Im going to put it on a lift on Monday and see what's up with it
              • H Offline
                H Offline
                hondagod2009
                junk it
                  TomTom
                  Seafoam FTW!
