  3. ICE and Detailing
  4. sub/amp problems
sub/amp problems
16 Posts 6 Posters 8.8k Views
  • wesholeW
    wesholeW
    Unhook the sub and see if it still does this. If it doesnt. its your sub that is blown. If it does, your amp needs repair or replacement.
    • civic91C
      civic91C
      civic91
      well the protection light doesn't flash when the subs are disconnected, so looks like they are blown.
      04 Toyota Celica Gts
      • wesholeW
        wesholeW
        one probably is for sure. but remove them and verify no wires are touching. then, hook one up at a time to see if one or both cause it to go into protect. If you can, have someone measure resistance of each sub with a multimeter to see what the ohms of resistance are.
        • blackcougarB
          blackcougarB
          blackcougar
          And if your sub is blown, I have a sweet 12" MTX 9500 series for you 🙂
          • civic91C
            civic91C
            civic91
            well i am just starting to look at subs again so send me some info on the sub and a price.
            • PSiedTSiP
              PSiedTSiP
              Did you check the resistance to make sure it's blown?
              spanish-rice;237125 wrote:
              • civic91C
                civic91C
                civic91
                pretty sure they are blown when i push down on them they make a bit of a grinding noise
                • PSiedTSiP
                  PSiedTSiP
                  Yep lol
                  • R
                    R
                    RuckU2
                    I had the same problem with a Phoenix Gold amp. Would go into protect mode. I blamed the sub, had it warrantied, and it was the amp. A resistor had burnt off the board and was causing the amp to go into protect mode under load.
                    • wesholeW
                      wesholeW
                      More often than not, it is the subwoofer that is blown. Hence the advice given to verify wether or not it was one or the other. While i have seen the same thing happen to other amps that you described, its not a common occurance and would be a diagnosis further down the road from the initial diagnosing. Good option nonetheless. Great to see others input.
                      • civic91C
                        civic91C
                        civic91
                        new problem with the amp/sub. so i got a new sub but when i hooked it up nothing happened. only light on, on the amp is the power light. its a 4ohm svc sub and im wondering if i just wired it up wrong or if there is something i could be missing.
                        • T
                          T
                          Trafik Jamz
                          Double check all of your connections (RCA inputs on amp/outputs on deck; speaker wires on amp, inputs on sub, etc...) to make sure signal is making its way from the deck to the amp. If any connections loose/unhooked, reconnect them.
                          While your old sub was out is it possible that the speaker wires shorted together? This can cause the amp to blow it's output channels which would mean the amp is dead/needs repair.
                          Also, you said that you got a new sub.... does this mean brand new sub purchased from a local retailer or does it mean "new to you" where you bought it on craigslist/ebay/some shady online store. If it wasn't bought brand new in box from a local store I'd say there is a 30% chance that you bought a defective sub that the previous owner knew was dead when he sold it.
                          What is the make/model of the amp and sub? I ask because it's possible (not necessarily likely) that if it is a low end amp that initially it had a surge/spike that took out the amp AND fried your old subs voicecoil simultaneously.
                          If you want me to spend 10 minutes looking it over for you I can do that as well for no charge.
                          701.541.3484
                          701.541.3484
                          • civic91C
                            civic91C
                            civic91
                            im checking all my connections right now. then im going to try and check if there is any power going from the amp to the sub. I have a feeling that there is something wrong with the amp but hopefully its just a connection.
                            The amp is a Rockford Fosgate p300-1 and the sub is a Kenwood KFC-W12. did not buy the sub in town, got it online bnib. also checked the sub after i hooked it up to the amp and got nothing and it seems to be fine but i would need to hook it up to a working amp to fully know.
                            Also while i was checking the ground wire, there was some speaker wire grounded with it. any idea what that would have been for?
                            • civic91C
                              civic91C
                              civic91
                              all connections seem to be good. so i tried adjusting some of the settings on the amp and now the protection light is flashing on and off again.
                              • T
                                T
                                Trafik Jamz
                                I'd really have to see it to know for sure at this point. As for the speaker wire grounded to the ground wire.....I'd have to see before I knew if that was a problem or not as well.
                                701.541.3484
