AE86 Project
so i thought it had been a while and so i should show a little bit of the progress i've made
I'm not familiar with AE86s, what is that/whatd you do to it?
here ya go man this is the easiest way to explain it ya
http://en.wikipedia.org/wiki/AE86 -
as for the pictures thats the lower crossmember and i have to cut a section out if it to clear the f20c oil pan but i still need to weld in the flat stock to reinforce the section i cut out
what color are you going to paint it?
i've actually been all over the place with the color but i have decided the go with Scion's Magnetic Gray Metallic
TomTom;324914 wrote:
What's your build budge with breakdown?I'm looking at about 5,000 for the main parts engine, transmission, drive shaft (with custom ends), ECU, engine harness, and mount kit with spacers.
After next summer when i boost, I'll probably be close to 10,000 total into the car but that could all change if i can find a wrecked car for cheap some where, but thats still all up in the air tell i try to do the mounts first. -
Joel;324988 wrote:
for 10,000, you could have a real s2000.... just sayin...at 10,000 i'm looking at some head work and boost and tune so your right for that price i could have a s2000 but this will be funner and lighter but to each there own
