  4. What did you do to your ride today?
35 Posts 8 Posters 6.5k Views
    [email protected];328162 wrote:
    I bought a Denso from rockauto.com - I believe it's the same as OEM.
    Picked up a 2.2k ohm resistor for the EGT connector and got it plugged in, need to take a drive on the interstate after work to confirm that it solved my P0546 DTC.
    edit Took a nice drive up to Harwood and back, no codes. :icon_cheers:
    Afterward I soldered up a proper resistor pigtail to plug into the harness.
    Denso would be correct for the oem; rock auto ftw when it comes to o2 sensors for Subarus.
    • legacy-user-351L Offline
      legacy-user-351
      ^ +1
      Today I finished detailing the engine bay, removed the tired hood liner, cleaned up the wheels, and removed the wiper arms, cowl, and A pillar trim in preparation for the new windshield tomorrow.
      I also hauled home 4 235/75r15 wheels and tires off of craigslist for my camper, without even having to put the seats down. Because racewagon.
      Turkeylord
      '05 Yamaha Zuma - Stock
        Peeled off the front bumper to repair it.
          legacy-user-351
          Front brakes were done about a month ago, finished up the rears last night.
          Centric Premium rotors and StopTech Street Performance pads all around now.
          Turkeylord
            legacy-user-351
            AEM Failsafe O2/boost gauge showed up yesterday, couldn't help but power it up on my desk at work...
            Turkeylord
              legacy-user-351
              Spring over axle conversion and bigger wheels and tires last night. No more scraping out of driveways and 65 mph trailer tires (had a blowout a month ago).
              Turkeylord
                I washed it and put gas in it.
                  a couple days ago i installed an ARB awning on my roof rack of my Subaru
                    legacy-user-351
                    Nice, I like that!
                    Turkeylord
                    • legacy-user-3898L Offline
                      legacy-user-3898
                      upgraded my fuel pump my in 90 camaro last friday and redid my tune a bit
                        legacy-user-351
                        One of the best tuners on LegacyGT.com was running a special on e-tunes so I couldn't resist - getting new tunes for both gas and e85. Heck of a deal for $200.
                        I got the new WBO2 installed half-ass so I'm ready to pull logs. I hope to button up the install this week, wiring up the failsafe output to cut the EBCS signal and getting everything tucked away nicely.
                        Turkeylord
                          legacy-user-351
                          Results are in, +6 HP, +11 TQ over my old gas etune, +6.6 HP, +21.4 TQ over my old e85 dyno tune.
                          :icon_cheers:
                          Turkeylord
                            legacy-user-351
                            Wrapped up a couple projects today.
                            Finished wiring up the failsafe output of my AEM wideband. Now it will use a relay to cut the signal to the boost control solenoid and drop me down to wastegate boost if I go lean or over boost.
                            Replaced the seatbelt in my driver's rear reel. Old one had an ugly stain.
                            Ran a 1/0 lead from the battery to the back. PITA. For future stereo use and for the following mod...
                            Rewired my fuel pump with 10 awg wire. Feeding it battery/alternator power from the 1/0. Stock was 18 awg, not enough - typically only saw 11.5v at the pump. I should have 13v+ now.
                            Pic below is the new 10 awg soldered to the stock wiring. Mmm, beefy.
                            My back hurts, lol.
                            Turkeylord
                              installed a borla header on my car cause the factory one was leaking.
                                Traded her in for a pickup!
                                  Put a new CAI on. I apparently will have a noisy power steering pump bearing now though.
                                    I heard you can hear CMK whining from even further away now!
                                      [legacy attachment 7155]
                                      Traded in my accord for my first full size pickup. 05 laramie 148k. stole it!
                                        legacy-user-351
                                        Put in a new Optima Yellowtop over lunch.
                                        Turkeylord
                                          you better go back and get a different sticker they put a 9/12 instead of a 9/13 on there!
