  3. Who was that?
  4. Red Rx-7 FD
Red Rx-7 FD
90 Posts 29 Posters 5.3k Views
  • AcesHighA
    AcesHighA
    AcesHigh
    That must be why F1 and Indy engines all rev to 10k and beyond...
    • drift86D
      drift86D
      drift86
      94NDTA wrote:
      Or that your internal parts are smaller/lighter so you don't need to fork out big bucks on as high quality materials as an engine with larger/heavier internals.
      How high your engine revs does not directly reflect how well built your engine is.
      ok look a rotary has 80% less moving parts than a conventional 4 cylinder which might not have anything to do with this argument, but since it has less parts, it is easier to balance wich makes it balanced more evenly than your v-8.quote from my automotive engines teacher. Also like any other motor they have problems and things brake or just get worn out. It isnt just from beating on it like you seem to make it sound.....
      oh and tell me how often have you seen a rotor get scored? so heavier components, yes, but mor expensive, no. oh ya it only takes two people to lift a rotary.... how many people does it take to lift yours?
      AE86 project: sold
      93 r33 gts25t new project
      00 impreza obs
      • drift86D
        drift86D
        drift86
        94NDTA wrote:
        It's not an opinion, it's a matter of fact.
        ya no he can choose do to what he wants, it is his car if you have already forgotten
        AE86 project: sold
        00 impreza obs
          And why RE-Amemia engines can rev to 13-15k..... I'm not claiming to be a rotary specialist, but it seems that people like to give them such a bad shake when it comes to reliability when they very little knowledge/appreciation of the genius masterpiece that is a rotary. If every motor company made a rotary, I guarantee that they'd be more reliable than they currently are. When only one manufacturer makes a rotary (and for only one car in their line-up at a time) there is really nothing to push the technology forward at the rate that piston motors are progressing.
          • 94NDTA9
            94NDTA9
            If you are trying to argue with me, this isn't helping your arguement. There is nothing saying an engine with heavier components can't rev high, it just takes more technology and money to do so.
              Ok then, name an engine with heavier components that is being used in motorsports that is high revving (above 10K). Maybe there is one, but I'm not aware of it. The reason they go with light components is two fold: 1 they want to rev high and 2 they want to reach high RPM's faster.
              • 94NDTA9
                94NDTA9
                You just agreed with me. Lighter components (or less moving components, I.E. Less mass being moved) will be able to rev higher than a larger (more moving mass) engine with parts manufactured at the same quality level.
                All I said, is how high your engine revs does not reflect how well built your engine is. There are are different factors other than how high it revs that determine that!
                It's a simple fact. It's not that in depth.
                Also, his engine was DESINGED to spin that high. If it FAILS to do so, to me that isn't as hihg of quality as I would have expected. If my car failed when it spun to 6,000 rpms, I would be dissapointed too. The technology in that car simply isn't far enough along yet to have it be as reliable as a piston engine.
                Also, what does lifting it out of the car have to do with anything?
                • RaiderR
                  RaiderR
                  Raider
                  DJ wrote:
                  Lets just clear the air, I have had the motor replaced once and the tranny replaced once also. The motor was replaced cuz of a faulty "side seal" it’s the seal that goes between the coolant chamber and the combustion chamber, it’s just like a head gasket. Marty (the rotary mechanic at Lunde) pushed to have the engine replaced cuz he just wanted to see a new motor in the car. Same deal with the tranny it didn’t necessarily need to be replaced but it was, cuz on the tranny the bearing on the output shaft in the tranny housing went out. That’s and ez fix, but he wanted to see the car get a new tranny, and it all was covered under warranty so why not, right?.
                  I question your statement on why the engine and tranny were replaced....I was the one who ordered both of them for your car and I know the history of your visit at the dealership
                  POWERD BY
                  • 94NDTA9
                    94NDTA9
                    I when I said heavier, I meant heavier than a piston made out of the same material only smaller.
                    Such as 4 pistons from a 2.0L I4 would be lighter than 8 pistons from a 6.0L V8, simply because it is larger, even if they were made out of the same material.
                    • 94NDTA9
                      94NDTA9
                      HE can do whatever he likes with his car. I never said he couldn't do anything he wanted to the car.
                      • 24valvenotak2
                        24valvenotak2
                        How can you compare the two? They are two totally different animals.
                        ...by the way wasnt a corevette(i thought) built with a four rotor but scrapped because it was too powerful for the average joe?
                        63vette;288530 wrote:
                        • 94NDTA9
                          94NDTA9
                          Never heard of it.
                          Also, I wasn't the one originally doing the comparing, I'm the one that said there are more factors.
                          Thanks for siding with me.
                          EDIT: found it. It was a 585 cubic inch engine making 420 hp....I don't think they scrapped it because it was too powerfull though...
                          • 24valvenotak2
                            24valvenotak2
                            94NDTA wrote:
                            Never heard of it.
                            I wasnt aiming that at you particularly, just the whole agrument in general. Its just like arguing over a v8 or a I4 nobody will win because they are built for different reasons to withstand differenty types of abuse ect.
                            I cant remember where I heard the four rotor thing..im probably wrong.
                            edit: I was right for once?
                            • 94NDTA9
                              94NDTA9
                              I found it, you were right, but they didn't make it because the sales were too good on the current vette. They were selling more vettes than they could make.
                              • 24valvenotak2
                                24valvenotak2
                                neat-o
                                • PhatsP
                                  PhatsP
                                  Phats
                                  ok, not to kick a dead horse here, and, not to step on any toes, but. That engine, in a completely stock form, can make a little over 500 horsepower, now, open it up and port it, that's how u get a little over 1800. Of course it's not exactly THAT simple, but you get the idea, to do that you need to be a stud, and have a great standalone system. But the moral of the story is that a rotary is a natural born killer.
                                  Now, do you wanna trade cars????
                                  02 GSXR-1000
                                  97 540i
                                  • EfiniE
                                    EfiniE
                                    Efini
                                    You that blonde dude that works there? That used to wash cars or something now you work in the service department? I am sure YOU ordered them.... Anyway I know why my parts went wrong, both my engine and tranny where reparable but Marty pushed for them to get replaced. Why would I have a reason to lie about why they where replace. If you do in fact work there, you would know that I drove the car there to get the engine replaced and I drove it there to get the new tranny also. The side seal went bad and was leaking coolant into combustion chamber, it was still drivable, the engine didn’t "blow up" nor did the tranny the ONE time I had it replaced.
                                    • EfiniE
                                      EfiniE
                                      Efini
                                      As for the quality of the parts that go in my motor like Sean is questioning, the only problem with the engine (specifically the I-III series 13b engine and earlier) was the sealing, from the side seals to the apex seals, Felix Wankel states that he never got the sealing quite right on the engine. But now with the new Renesis engine they moved the exhaust port to the side of the rotor housing rather than having the apex seals pass over the exhaust port and getting worn out. The new Renesis looks to be a very promising engine. For example my car makes 255hp stock, the RX-8 makes what 238hp naturally aspirated, on the same displacement engine. They achieved that all by just adding intake and exhaust ports. Also the internal combustion engine was invented in the early 18th century, the rotary was invented in 1957. That’s what 150years? I think you see my point. Along with what Chuck said. Only time will tell where the Renesis stands for reliability, I think you will be eating your words.
                                      • bluejaysB
                                        bluejaysB
                                        bluejays
                                        i may be wrong but i think i heard that the new rx8 was dual rotary powered? am i wrong or not?
                                        • STiSchuckyS
                                          STiSchuckyS
                                          yeah. but its 190 or so whp which is what matters. thats why mazda bought a lot of htem back. lack of horsepower
