  4. Does any body use a pucked clutch
27 Posts 5 Posters 2.6k Views
  • T
    T
    TRE
    so I will get use to it is what you are saying? I want a 4 puck, because of less rotating wieght and they say if you have a smaller disk that a 4 puck is alright, I only drive my car when i fuck around with it on the streets, I dont do any dayily driving ya know... but i am in traffic somtimes and whatever. So more info would be great. I would like to know before teh end of the night if that is possible, thanks. I have to make a quick desision, becuase I got my new tranny and i need to know if i feel like getting a new clutch too. btw, I had a custom tranny built with custom gears, a new 4.2 final drive and a helical TRD LSD just thought i would throw that in there so u would know what we are dealing with, thanks
    • 24valvenotak2
      24valvenotak2
      I wouldnt think you would need/want a pucked clutch with the application your dealing with. The less rotating mass bullshit....lift both at the same time. An organic is not exactly heavy by any means. Unless you are counting every ounce(obviously your show car is not) or pushing 3000ft lbs of torque..I would not buy a pucked clutch, especially not a four puck.
      63vette;288530 wrote:
      • T
        T
        TRE
        I think i found what I am getting, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7916716601&fromMakeTrack=true that be the bitch there, it says it is for a mr2, but after doing a little cross ref, i found out it is for the 4efte ep-81 tranny, witch is the one I got built, I am looking into the future as of now, I am upgrading my turbo and motor this winter so.. might as well do this now, I have another question, I just got a new throw out bearing 6000 miles ago, do u guys think i need another one? cuz I have no Idea what throw out bearing I need, i was thinking i could just slide by without getting one, but I have heard it is a good idea.... Any thought on this?
        • 24valvenotak2
          24valvenotak2
          Save yourself the trouble and get a new one... they are cheap. If you are cheap just remember to grease it up again..that shit gets annoying real fast.
          • T
            T
            TRE
            Im not cheep I just dont know how to cross reference a throw out bearing, here is a quesiton, if a clutch will work from a 2002 MR2 does that mean the throw out bearing will too? thanks in advance, by the way what do you think of that clutch? any good?
            • 24valvenotak2
              24valvenotak2
              I would bet that if the clutch from the mr2 will work in your car so will the throw out bearing that is listed for that clutch. As for that clutch, if its indeed a true trd product, I wouldnt be scared of it....have you found a plate for it yet?
              I hope you dont plan on trying to slip that one........
              • T
                T
                TRE
                Yep the plate I found is the matching TRD plate for the clutch I showed you. But for some reason it doesnt come with a throw out bearing (as far as I know) I will order a factory thorw out bearing then from toyota for a MR2 and we will see how it goes, thanks for your opinion and help.
                • integra_gsr98I
                  integra_gsr98I
                  What I am trying to say is you do not want a 4 puck, and if I was you I wouldn't even go with a 6 puck. Having only run pucked clutches in my life (other than when I had my DSM, and even then I made the mistake to try a sprung 6 puck) I am in the process of completely switching away from them. They are too violent engagement wise, and I would rather deal with replacing discs once and awhile than to snapping other drivetrain pieces.
                  • T
                    T
                    TRE
                    Ah I see that makes sence I guess, well I think I am going to try that 3 puck TRD clutch and if I dont like it I will just get a different one, I am always up for new things so a try wont hurt anything, This TRD one looks pretty sweet, It is a Japan only clutch and they ussually make pretty good shit so I am going to try her, I will let you guys know how it goes.
                    • PSiedTSiP
                      PSiedTSiP
                      omg 3 puck...good luck
                      spanish-rice;237125 wrote:
                      • T
                        T
                        TRE
                        be just like a 4 lol, it either grabs or it doesnt, on/off switch right? im sure it will be fine, if not i will just have to break down and get something else.
                        • 24valvenotak2
                          24valvenotak2
                          grabs or it doesnt....HA
                          • T
                            T
                            TRE
                            well, it is intersting, I got it all in, might I add the LSD rocks real glad i got that unit, and the new gears in the tranny are great. pulls hard in all the gears. The pucked clutch is real intersting though, I havnt killed it yet, drove around for like an hour in heavy traffic, but it does chatter a bunch if you dont do things just right, it is really great when you are on it and shifting through the gears, I dont mind the chatter ness, I just worry that it is breaking something, it just sounds bad sometimes.... Is there anything that can break cuz of that? thanks.
                            • integra_gsr98I
                              integra_gsr98I
                              Sure. Pucked clutches engage hard enough that they can break differentials, axles, etc. That is why I myself am switching back to a street disc. There is no way to "preload" the drivetrain with a pucked clutch and that is what tends to break shit.
                              • T
                                T
                                TRE
                                hum... well, I will drive it for a bit here and see if i get any better at driving it, the thing is I love that thing when i am already going along, but the thing i dont like is starting out from a stop and worring about breaking something. It is something I am going to have to decide here.
                                • integra_gsr98I
                                  integra_gsr98I
                                  Any fresh aftermarket clutch will engage nice when driven hard when it is new. 🙂
                                  I have a pucked clutch in my integra right now that I'm too lazy to pull out that I can slip like a street disc. That's not right either. 🙂
                                  • T
                                    T
                                    TRE
                                    I was thinking of pulling it.... kinda really thinking about it. so... what do u think.
                                    • T
                                      T
                                      TRE
                                      I just cant see my self always paying attention to what i am doing ya know.... the sec i stop thinking about it. boom i kill it lol.
                                      • T
                                        T
                                        TRE
                                        alright here is a question for all of you pucked people, so I was really thinking of getting rid of my disk, cuz it was so harsh, but i went driving today and it got less harsh.... is it because of the weather or do they kinda break in and get a little less harsh ya know what im saying? Thanks please fill me in on this.
                                        • integra_gsr98I
                                          integra_gsr98I
                                          Well it really wouldn't be an instant change. How many pucks were on the clutch? If there are less than 6 I would ditch it just because it will continue to be a pain in the ass. 6 pucks are livable, but not what I am personally looking for anymore.
                                          That or I'm getting old and I'd just rather deal with street discs. 🙂
