tranny probs again
I have already talked to someone about this but more info is always better. For some reason when I have my clutch pedal to the floor while in gear and push on the gas, the car still moves. I have to rev match it to up shift. down shifting is out of the question. I just put the tranny in and it shifted smooth all day. The next day my tranny bolts started to thread themselves out again, so I tightened them back up and drove for a while. About ten minutes of driving I couldnt shift at all and the bolts were still tight. Help me
Sounds like the clutch isn't disengaging. stretching cable? or if hydraulic, maybe air in the system?
torbs wrote:
it coulda been, idk, nick's gonna check it out to see whats up with it...There is nothing wrong w/ your flywheel if it worked before. If the problem was the flywheel you would have had the problem since day 1. My guess for your car is a failing pressure plate or pedal assembly.
As for yours there's a bunch of little tricks to try, but they all involve removing the trans. Drop it off, i'll find the problem and fix it :-).
How much is it gonna cost? I have money but dont want to spend a shit load of money on something I can fix myself. I'm not car illiterate, I just dont have the patience to do it myself. Ill drop it off when I have cash cuz I plan on getting an LM1
PSI2HI wrote:
There is nothing wrong w/ your flywheel if it worked before. If the problem was the flywheel you would have had the problem since day 1. My guess for your car is a failing pressure plate or pedal assembly.yea, w/e it is, lets just hope that its cheap
