4G63 Civic Hatch
Stock 4G63. No need to build these motors. I ran a stock rod, stock head, stock 2G piston motor in my 93 that laid down 530whp. I'll run race gas on 30 psi on this. Goal is very cheap 400whp sub 2000lb car. Might even run a NA bottom end for the compression.
Gonna try push this project along quickly and have it ready w/in a month or so. Only downtime will be getting the axles splined for Honda hubs. Otherwise everything should be a breeze once all the mounts are built.
Nick
SLS -
PSiedTSi wrote:
mwc youd be gettin rid of one of best motors made...that thing is indestructablethat may be true...but a friend of mine went to wyotech and while he was there he pulled up to a 2g eclipse alls he could see on the inside was a lime green rollcage and the guy smoked him....he pulled over after the race and the guy had a 383 stroker in his eclipse.
mwc1 wrote:
that may be true...but a friend of mine went to wyotech and while he was there he pulled up to a 2g eclipse alls he could see on the inside was a lime green rollcage and the guy smoked him....he pulled over after the race and the guy had a 383 stroker in his eclipse.Bah, you can get much better power-weight out of the 4g63 unless you are going to turbo the V8....
Quit whoring the thread anyways, this is about Nick putting a 4g63 into his hatch. What are you plans with the axles? Just get some DSM axles cut and resplined? That is pretty much the only difficult thing to do. Do you know of a place that can do it?
