  4. Oh...for the love of traction...
18 Posts 8 Posters 1.2k Views
  • 94NDTA9 Offline
    94NDTA9 Offline
    DaveH wrote:
    Are those ET Street Radials?
    No, just regular ET streets. They are going to be track only tires that I will put on my old (much lighter) rims.
    • 0 Offline
      0 Offline
      03SVT
      The ET Street Radials are what I am going with ... they hook pretty good.
      • 94NDTA9 Offline
        94NDTA9 Offline
        You are right. I could have gotten away with the radials, but these are track only, so I decided to go the extra step.
          brokedsm
          looks like a good setup
          • 94NDTA9 Offline
            94NDTA9 Offline
            I hope so.
              adog
              What do you have for a rear on the car?
              • 94NDTA9 Offline
                94NDTA9 Offline
                Stock 10 bolt, with 3.23 gears. It is an automatic, which do not go out as much as the manuals. I just need it to hold for one season, or else I am screwed.
                  adog
                  Right now I'm pretty much in the same boat. I have 2.73's with an A4, and I'm trying to decide if I should get a rear or a transmission first.
                    adog
                    Quite the setup, by the way.
                    • 94NDTA9 Offline
                      94NDTA9 Offline
                      2.73's are a major downfall, especially on an LS1 without an aftermarket converter. I have seen your dyno numbers on LS1tech, don't even bother throwing deeper gears, just save up for a 12 bolt or 9 inch. As for the Tranny, your 4L65 is a tad stronger than my 4L60, so you might get away with it for a while. I am having CPT in NJ build me a manual valve body 700R right now, coupled with a fuddle TQ converter. I have been in conversation with Frank for a while, he has a lot of confidence in his trannies. Hopefully this will withstand the power I want to put through it in the future, if it doesn't, hello TH400.
                        adog
                        Yeah, I think the 10 bolt will go first, as they're a bit notorious for that. Plus, I'd like to get a torque converter installed at the same time as the transmission, and that would guarantee the destruction of the stock rear.
                        • 94NDTA9 Offline
                          94NDTA9 Offline
                          There are quite a few stock 10 bolts in the 11-10 second range, I am hopeing mine will be one of those.
