nitrous?
i have heard quite a bit about swapping the engine. some love it and some say its not worth it. as far as a 5speed...news to me, definitely something to check into. what kind of shift kit would i put in the automatic that i have now?...where would i find one? i've looked on the Hahn site and i didn't find a turbo for the V6. if you know where i can find one for a decent price, let me know. as i've been watching this forum and gathering info. on nitrous, i'm leaning toward purchasing a ZEX wet nitrous kit w/ the smart box. i won't do so for some time but that's where i'm headed. and for a back-up car...no, i dont have one but i was thinking about just buying a salvage 2.5 V6 like mine and doing a port and polish and maybe bore it out. i figure if i start doing that this summer, i can have it finished by the time that my engine goes.
thanks for all the input guys...keep it coming.
you could use nitrous easily its just the shot u use u could use a 50 to 75 shot on the car easily and safley
wizard, you seem to be ignoring the "broke college student" remark... as our grease monkey friend put it, i wouldn't go about beefing up the car with that kind of mindset. when something breaks and you've got no back up car or funds to fix it...
as far as your engine... the 6g73 seems like the black sheep of mitsubishi's family, it is generally regarded as no being worth the time to mess with. i remember asking caleb about a turbo for the 6g73 in an avenger (one of my friends had one at the time), and he said that the engine bay is incredibly cramped and that it would be too expensive/difficult to do it for the nominal gains -
Imagine trying to fit a 6 cyl engine in an engine bay the same size as a 2G Eclipse, becuase thats basically what they did.
That being said, you should be able to run a 50-75 shot atleast safely, I know the 420a's can take atleast that and you have a slightly bigger motor. Might want to check out fuel pumps while your at it.
Not really....the Avenger/Sebring has much more space under the hood than an Eclipse. Mostly due to the front end design isn't set back as far and the headlights are flatter. Here's some pics of the 3g turbo-kit from www.ddynopower.com. Should give you an idea of how cramped it would be. But imagine a little more engine bay space at the corners and a bit more room between motor and radiator.
http://ddynopower.com/pics/engine3.jpg
http://ddynopower.com/pics/engine1.jpg
http://ddynopower.com/pics/engine2.jpgBut as for the 'broken college student', I must have missed that....sorry. I agree that you should look for a beater to drive if you plan on modding your car. Rule of thumb for any car....especially DSMs.
While I agree that the 6g series motors are junk to build (notably the 6g72 and it's amazingly high oil pump failures), I was just providing options.
Wiz
adog wrote:
If the engine bay is really cramped, you could always do something insane like put the turbo in the rear, but there's no way that will ever work well.
It has been done, and isn't much different than strapping a turbo on the manifold aside from a very small power loss (compaired to turbo on manifold) if done properly. -
Wizard wrote:
While I agree that the 6g series motors are junk to build (notably the 6g72 and it's amazingly high oil pump failures), I was just providing options.Wiz
I disagree....if changed at regularly scheduled intervals(as directed by the owners manual) it does not fail as often as you make it sound. I think the water pump is more of an issue then the oil pump and, as the oil pump, should be replaced every 60k miles.
I also dont exactly think there is much sense in "building" the motor..since they have been proven to handle 400+hp. I will be honest and agree that they like to spin bearings if treated poorly, but so do lots of stock motors with 400hp. I think they would have a bit more respect if there were more then three fast 6G powered cars out there, because they are not hard to make power with. Im not trying to start a fight or whore, I drive one and thought I would stick up for myself because I dont think they are junk.
^Yea, they are not exactly a piece of cheese.....
Well i'm just considering the overwhleming number of 6g's out there with spun rod bearings, etc. And while they may make some power, they are much like the 2JZ....800hp just to run 9 or 10s. Poor powerbands mixed with poorly geared trannies.
And as for the oil pump and waterpump needing replaced at 60k......I can't think of any other cars that this is necc. to maintain proper operation. Timing belt for a 4g maybe. But my car has 132k miles with original oil pump, water pump, etc. And everything is just peachy on it and she makes great power. I know of many others with even more miles still on original equipment without failure and they are abused motors.
And from what I heard, Len Monseratt and Wrighttouch Racing tried to make this motor a serious contender in Pro-Classes and it did nothing but kill the bottom-end consistantly. Neither car has made full passes down the strip and have both been down since 2002. Not saying that times may change with a good builder/tuner. But as of yet, they have not been a very good motor when modified.
Long live the 4G (Since 1972 BTW).
Wiz
[QUOTE=Wizard]Well i'm just considering the overwhleming number of 6g's out there with spun rod bearings, etc. And while they may make some power, they are much like the 2JZ....800hp just to run 9 or 10s. Poor powerbands mixed with poorly geared trannies.[QUOTE=Wizard]
Spun rod bearins is a known problem..but why does that make em junk? There are more then four cars out there running 400+hp on stock bottom ends. I think I might be one of them come summer. 800hp seems like a lot...but not when your car weighs two tons. Dave runs nines with a shade under 900hp as well. Poorly geared trannies? Maybe....but so is a DSM tranny. Unless people steal galant first gears because they think it sounds cool.
[QUOTE=Wizard]And as for the oil pump and waterpump needing replaced at 60k......I can't think of any other cars that this is necc. to maintain proper operation. Timing belt for a 4g maybe. But my car has 132k miles with original oil pump, water pump, etc. And everything is just peachy on it and she makes great power. I know of many others with even more miles still on original equipment without failure and they are abused motors.[QUOTE=Wizard]
Replacing the oil pump at 60k miles as a precautionary measure might sound like a pain in the ass..but its not that hard. A v8 needs a distributor, rotor, cap ect about as often, at least in my experience. It comes with the territory and I while it might not be fun, I dont mind working on my car. Besides, 60k miles wont roll around for me until im thirty.
[QUOTE=Wizard]And from what I heard, Len Monseratt and Wrighttouch Racing tried to make this motor a serious contender in Pro-Classes and it did nothing but kill the bottom-end consistantly. Neither car has made full passes down the strip and have both been down since 2002. Not saying that times may change with a good builder/tuner. But as of yet, they have not been a very good motor when modified.[QUOTE=Wizard]
Progess has been nonexistant for these cars from day one. Aftermarket doesnt exist and support from owners is limited to a handfull when it comes to engineering and pushing the platform forward. Anyway, how many different motors are pro-stock material.... I would say what, a handfull of teams use different motors/setups and are still competitive? Drag racing at that level leaves little to innovation. They use whats proven and stick to it IMO. The amount of time and money you would need to make a 6G a contender is something few teams have or. If you ask me, nobody cares or will care for it because they are not cheap. They arnt cheap to own, build, or maintain. But I love em and if prostock wont have em then o well. The 1000+ members of 3SI along with myself will take allthe extra ones we can get.
[QUOTE=Wizard]Long live the 4G (Since 1972 BTW).[QUOTE=Wizard]Long live every car and everyone who enjoys the sport...except cavaliers. They can go to hell.
edit/ that got a bit whorish...oopes.
hey, thanks guys...keep it comin'.....
Im not "hating" either....I just dont think one downfall is enough to label it junk.
