  4. Is there somthing wrong with my car
19 Posts 8 Posters 3.5k Views
  • H Offline
    H Offline
    Hatchling
    Ok here is a another vid of my car driving it is during the day so you can get a better feel for how bad it smokes. there is swearing in both vids the first on in a hiway pass and the second in an in car.
    Right click save as
    Right Click save as
    Have fun and watch safely
    p.s. sorry about the chick in the back ground she is weird
    • Afsil80A Offline
      Afsil80A Offline
      Afsil80
      I've seen it in person, but I don't have a picture when I play it...anyone know what version of QuickTime I need?
      -Peter
      1991 240SX
        we-todd-did-racing doesnt support this site. you need to either add this site to their list, or find someone else to host them for you.
          lmao @ the chick. WOOOOOOOOOOOOOOOOOOOOOOOOOOOOO HES STILL GOIN! CHECK OUT THE FUCKIN SMOKE THATS STILL FLOATING THERE. Dang ricer
          • W Offline
            W Offline
            Wizard
            Either you've got a problem with your PCV/Crankcase system or your oil control rings are shot. But with it only smoking under throttle, my guess is rings. Do a compression test. Both dry and wet.
            Wiz
            1992 GVR4 598/1000 Nile Black
            1992 Tsi AWD
            1982 Datsun KC 4x4
            1990 Laser 2.0 AT NT
            1994 ES 2.0L NT 5-spd
            • drift86D Offline
              drift86D Offline
              drift86
              Wiz
              it very well could be a bad valve seat
              AE86 project: sold
              93 r33 gts25t new project
              00 impreza obs
              • W Offline
                W Offline
                Wizard
                A bad valve stem seal usually only smokes during idle and initial start-up. And a bad valve seat doesn't cause a car to burn oil under load like that, actually at all. If the guides aren't worn and the stem seals are still decent, it won't burn oil at all. Just be a little low on compression. Worn guides and bad valve stem seals will cause oil consumption but usually it won't be just under WOT. Which is why I am pointing towards PCV or rings. It's gotta be something that changes under a load.
                Wiz
                1992 Tsi AWD
                1982 Datsun KC 4x4
                • H Offline
                  H Offline
                  Hatchling
                  ok here is the deal compression 190+ all cyc (WARM ENGINE BUT DRY TEST). Leakdown lessthan 5% Head was inspected it cheaked out good in tearms of valve guides and cracks. the botto end has 115k on it. the vavle seals are good just replaced before install (sat for about three months). I am nthinking the rings are bad. the intake is bad (oil covered) up to the TB BTw I am running 20-50 during that run it was worse when it was 10-30
                  Hehehe the fastest mesquetoe sprayer in the midwest.
                  • H Offline
                    H Offline
                    Hatchling
                    need to right click and save it or open it and you are going to need .mov player like quick time
                      i did that for both of 'em and the whole video was just a 'this site is not supported' picture.
                      • H Offline
                        H Offline
                        Hatchling
                        • H Offline
                          H Offline
                          Hatchling
                          try opening in a new window BTW fargo street is now a suported site
                            That is a ton of smoke.
                            What engine are you running? Dx/z6 head?
                            • H Offline
                              H Offline
                              Hatchling
                              yeah that is the combo
                              • H Offline
                                H Offline
                                Hatchling
                                I should have taped it when i was running 10-30 oil
                                I am running 20-50 right nowm glad i didn't pop for the Royal Purple
                                  Has it always smoked? Did the d15 smoke? What condition was the z6 head in?
                                  I know a common problem when putting a higher compression head on a low compression bottom can wear on the rings pretty quick.
                                  So if the DX rings were already shot, then this would just multiply the problem.
                                    that's is really funny. i think my car is bad, maybe we should do a side by side roll and see how much more oil you urn then i do!
                                    • H Offline
                                      H Offline
                                      Hatchling
                                      the z6 head was cheak out by a macine shop and past as a good head the bottom end smoked a bit so that is why i think it is the rings.
                                      BTW i would be more than happy to do a roll side by side. My car is still quick so if you get stuck behind me sorry
                                        lol, i was think of coming up on saturday for shits and giggle to have some fun, maybe if i do come up, we could do something.
