  4. TBI To FI
TBI To FI
8 Posts 4 Posters 486 Views
  • M Offline
    M Offline
    MrScary
    Ok my 3.8 V6 Stang has TBI. I'm wanting to swap a FI system from a T-Bird and maybe a supercharger from one. Anyone know if this will work? Some people say yes some say no.
    • RaiderR Offline
      RaiderR Offline
      Raider
      when u go to the FI system you have to run a different PCM...it would work if you bought the whole intake system with the wire harness and PCM
      POWERD BY
      • M Offline
        M Offline
        MrScary
        Yea I knew that. So would the supercharger also work if I have the PCM? Also need some info about getting a cam. Was looking at a website and they have one that is around .030 in higher then stock on lift and then theres one that was .060 in. I'm just wanting something that would be able to perform but not be crazy when I'm not at WOT.
        • FlowcusF Offline
          FlowcusF Offline
          Flowcus
          Well if your wanting just some performance for the street and strip go with the .030 lift... if you want a lot of performance for the strip go with the .060. If your going to be adding a lot of fuel ( expecially if you go with the supercharger ) definately get the .060
          I ride random bitches.
          • M Offline
            M Offline
            MrScary
            Would the .060 be alright for daily driving??
            • FlowcusF Offline
              FlowcusF Offline
              Flowcus
              Well thats hella lift for just adding that without mods. I guess id add some fuel mods with that big ass cam.
              • D Offline
                D Offline
                dynotune
                Before you dig into cams at all, you'll need to do something with that shitty EFI. TBI is not adequate for any perf app- ideally you'll need a MAF system. If you want to run a cam of any size worth installing, speed density will NOT work worth a shit. The calibrations are not supported w/ any tuning hardware (diablo, superchips, etc) and many are EEC-III. If you want power w/o digging into that, start putting exhaust and gears into it first- best bang for the buck w/o getting in over your head
                DynoTune Speed & Performance
                Mobile chassis dyno service
                www.dynotuneusa.com
                (605) 753-1101
                • M Offline
                  M Offline
                  MrScary
                  Yea I prolly won't go with a new cam until I get some bolt ons. I know I will need a new fuel pump and lines to go with the S/C. Would an MAF come with this system? And what years did the T-Bird have the s/c? Also would I want to pick up a wideband sensor and anything else for tuning?
