Updates on Fallguys Probe
Since you are already calling it a mutt, you should just mold those headlights you have for sale into the front bumper....
....and change that emblem to Foyota.
Wow, looks like you didn't have to cut a whole lot of stuff in that!
are you going to have to moddify the hood at all?? -
Just a couple of update pics... it's coming along nicely. Since these pics were taken I have the driveshaft in and it fits good. I have the front driveshaft loop in. I also have the main drivceshaft tunnel complete.
Mount for the nitrous done.
Wilwood master cylinder is hooked up to pedal.
I got the window net complete too.
Here's another one of net.
Is the steering all finished up now too?
integra_gsr98 wrote:
Is the steering all finished up now too?Yep.
I welded in a 1 inch pipe to connect the two frame connectors and welded on a couple of bolts and then the rack mounted to the bolts. Worked really nice. I still have to setup bump steer, but for the most part it is done.
tqisking wrote:
You do know that the window net is not supposed to be mounted to the outside of the cage....that is about all I see that should be changed otherwise looks like a nice race car....Chad
Thanks Chad...I saw a few pics of supra's with the net and that's how they did theirs....I assumed the installer knew what they were doing. I'll check it out....easy fix...if I need to.
Also thanks...it going to be a nice "streetable" race car.
