  4. loose carbs?
loose carbs?
33 Posts 11 Posters 2.0k Views
  • wesholeW
    wesholeW
    Me too, god knows I could use it. Sorry for whoring.
    • 2wheeler2
      2wheeler2
      2wheeler
      Roller28 wrote:
      also what are you using for fuel? No matter what, you ned to be running the highest grade fuel possible for optimum performance. No exceptions what so ever.
      Please explain "grade". Are you speaking of octane levels?
      '08 Suzuki Hayabusa
      '09 Yamaha Zuma 200cc
      '95 E-350 7.5L
      • Roller28R
        Roller28R
        Roller28
        jct_4628 wrote:
        everything is stock except for a KN filter and a Vance and Hines exhaust.
        so then you need to re jet the bike because it needs larger jets to work properly with the more air flow, and free flowing exhaust. I sell jet kits here in CA.
        1987 Toyota Pickup 4X4 (lifted)
        1999 Honda CBR900RR
        2001 Yamaha Raptor 660
        2006 Honda Civic Coupe (wife's)
        Wife with Bolt on's, what else could you ask for?
        • Roller28R
          Roller28R
          Roller28
          yes octane levels, they call it grade of fuel such as 89, 90, etc..
          1999 Honda CBR900RR
          • 2wheeler2
            2wheeler2
            2wheeler
            Then I'm gonna have to disagree with you. For highest performance, I would go with a fuel such as VP MR9. It's 87 octane, but you'll prolly see a good 5-10 HP on a dyno with no fuelling changes.
            '08 Suzuki Hayabusa
            '95 E-350 7.5L
            • Roller28R
              Roller28R
              Roller28
              Whats to disagree with? I was just telling him about the grades of fuel, not what grade to put in the bike!
              1999 Honda CBR900RR
              • Roller28R
                Roller28R
                Roller28
                How can you get 5-10 hp out of an 87 octane fuel? Explain...............................
                1999 Honda CBR900RR
                • Roller28R
                  Roller28R
                  Roller28
                  First of all, in a street bike you do not want to run straight race gas, you want to mix it 50/50. I have seen way to many engines take a crap because it can not hold up to that gas. GP bikes run this gas for a reason, because the engine can handle it. I still don't see someone getting 5-10 hp from the gas, do you realize how hard it is to squeeze more HP from these bikes, esecially a carburated one! If you are the average rider on the street, just run the top pump octane you can buy, otherwise you are wasting your money.
                  1999 Honda CBR900RR
                  • 2wheeler2
                    2wheeler2
                    2wheeler
                    Unfortuately, you're wrong. MR9 is highly oxygenated and that is how it makes power. As far as using it on street bikes, it is just fine. It will cause no damage. A friend of mine, Robert Jensen, who is the current F-USA road racing champoin in both the superbike and superstock classes uses it in his bikes. They are both limited to STOCK internals. His CR is raised to somewhere around 14:1 and he uses MR9(87 octane) in both, and they hold up fine. He sees around a 10 RWHP gain with that fuel.
                    As far as straight race gas, what fuel are you speaking of? VP makes over 30 different fuels alone.
                    And engines taking a crap from race gas? That one is new to me. The only bad thing about a fuel that I've seen is how Nutec will eat through fuel lines if not purged each day.
                    Oh yeah, and just this spring, Arcane Racing "squeezed" 701 HP from a Hayabusa. Stock was prolly 155-160. So, there's some room to move in the HP department.
                    '08 Suzuki Hayabusa
                    '95 E-350 7.5L
                      Ethan is right, and I gotta chime in here too. Fist off, high octane fuel doesn't make more power by itself, in fact since its harder to burn it may make less power. What high octane fuel does do it reduce knock. That is all the octane ratings really mean.
                      So, you're now probably asking why use high octane fuel if it doesn't add power? The answer is simple: It reduces knock which adds a layer of safety to an aggressive tune. For example, lets say that you can squeeze 200 whp out of a vehicle on pump gas w/ 18 psi of boost before knock, you should be able to run a bit leaner and/or turn up the boost and/or advance the timing if you run C16 which should in turn get you to a higher whp.
                      • FlowcusF
                        FlowcusF
                        Flowcus
                        Funny guy... Word of advice. Dont argue with ethan about bikes, you wont win.
                        I ride random bitches.
                          what he said^^
                          • jct_4628J
                            jct_4628J
                            jct_4628
                            I put some sea foam in there...seems to be working better.....
                            Jason
                            -06 WRX
                            -95 CBR 600F3
                            701-541-2568
                            • Roller28R
                              Roller28R
                              Roller28
                              I guess I should not try to compete with you, since you are so knowledgeable about bikes, right? Whatever. This is not a competition what so ever, I was just trying to help someone out, and you took it way out of context. He has a jetting problem, not a fuel problem. And not to mention it is a carburated CBR 600, it is not ment for a speed demon, it is ment for riding. Come on people, quit trying to prove you are so knowledgeable, and enjoy the motorcycle for what it is ment for, RIDING! O, I forgot you can only ride 3 months out of the year there! This is not a pissing contest, I was just trying to help someone out. Come out here to California and ride with me sometime, then we will have a pissing contest!
                              1999 Honda CBR900RR
                              • HandoEXH
                                HandoEXH
                                In Roller28's defense, ^ how is this not true? It was my understanding that higher octane fuel was recommended for a bike like jct's.
                                  But he also said that race fuel has blown up some engines that can't handle it. All Ethan and I were saying is that Race gas doesn't add HP, it adds safety.
                                  • 2wheeler2
                                    2wheeler2
                                    2wheeler
                                    If the bike ran fine before, then the jets are correct. It is probably in need of a cleaning and inspection.
                                    Not fast, eh? That bike won the AMA 600 Supersport title in '95.
                                    '08 Suzuki Hayabusa
                                    '95 E-350 7.5L
                                    • 2wheeler2
                                      2wheeler2
                                      2wheeler
                                      I'm on your side here Chuck, but oxygenated fuel does add HP, with no other changes to the fueling, engine timing, or forced induction.
                                      '08 Suzuki Hayabusa
                                      '95 E-350 7.5L
                                      • Roller28R
                                        Roller28R
                                        Roller28
                                        Why do you people have to get so F'n technical? Clean the jets or change them out, I was just trying to help this kid, and yall have to jump up my ass about this! And whether the bike won a championship 10 years ago does not matter, try runinng that bike vs a new 600! You all spend way to much time in doors during the winter time, I swear!
                                        1999 Honda CBR900RR
                                        • SmitEvoS
                                          SmitEvoS
                                          Because this is fargostreet and we love drama.........;)
