First Thread.
...and you should be careful what it is you are applying it to. it has been known to break windows, door frames, and even heave foundations.
Civic42 wrote:
well sound only matters from the inside right forget the foam and jsut enjoy the musics....and a few bumps never hurts nothingWhile this is technically true that it only matters on the inside there is a huge advantage to reducing rattles since harmonics caused by rattles can in fact cancel out frequencies that you want to have playing. In fact, by applying dynamat or any other sound deadener (Roadkill, brownbread, Cascade, etc....) you can effectively quiet the interior to the point where it would be the rough equivalent of doubling your amplifier power. Its not uncommon to gain 3 decibels of sound pressure by stopping rattles...and 3 decibels is the same as doubling your amplifier power. Just to clarify, that does not mean it is twice as loud. You need to get 10 times the amplifier output (on the same number of speakers) to get twice as loud (10 decibels). In other words if you make 90dB at one watt w/ 2 watts of power you will only make 93 dB; w/ 10 watts you will make 100dB, w/ 100 watts you will make 110 dB; and w/ 1000 watts you will make 120 dB (and this is only in a perfect environment, usually you make less of a difference by going up in power by 10 times the normal amount...say 7-8dB for every time you increase power 10 times)
amicheze wrote:
i had a pretty decent system in my old car. nothing too fancy, but it pounded pretty well in an old grandmamobile. i kinda wish i still had it.. or at least the money for it.. cough
i gave you a $300 deck and more then $300 in speakers for free...
^^^^^nova, can we get a translation?^^^^^
