Xbox 360
Games def will play a huge roll in who will want to play which system insead of the other. Seing how xbox will run with IBM technology is pretty sweet too, they make the fastest computer on earth right now, so you know it wont be underpowered. I'm not sure what PS3 will run with, could be IBM as well havent looked yet. But whatever happens i will really want either of them
amicheze wrote:
the processing power/graphics will be about the same im sure.. so the machine itself wont matter. its the games that will make or break the system. you can have the most badass machine imaginable but if you have nothing but shitty games, it wont matter.kinda like gamecube....lots of great potential but crappy games... i mean look how freaking awsome resident evil 4 looked.. to bad they dont have more of them
the thing I didn't like about GC was (at least at launch...maybe this changed) you couldn't play a regular DVD in it. Not that DVD players are expensive, just seems that if it had DVD options, more people might give them a look... But then again nintendo has been known for doing some odd things that have hurt sales over the years (cartridge based N64 for example...and breaking off a joint relationship with sony to produce a gaming console)
tjamz wrote:
the thing I didn't like about GC was (at least at launch...maybe this changed) you couldn't play a regular DVD in it. Not that DVD players are expensive, just seems that if it had DVD options, more people might give them a look... But then again nintendo has been known for doing some odd things that have hurt sales over the years (cartridge based N64 for example...and breaking off a joint relationship with sony to produce a gaming console)they basically did it to be the cheapest on the market...not the best...it was a value thing...i believe they struggled to decide whether or not to have a dvd player right up until the end...
Source: http://ps3.ign.com/articles/614/614682p1.html
Cell Processor
PowerPC-base Core @3.2GHz
1 VMX vector unit per core
512KB L2 cache
7 x SPE @3.2GHz
7 x 128b 128 SIMD GPRs
7 x 256KB SRAM for SPE- 1 of 8 SPEs reserved for redundancy
total floating point performance: 218 GFLOPS
GPU
RSX @550MHz
1.8 TFLOPS floating point performance
Full HD (up to 1080p) x 2 channels
Multi-way programmable parallel floating point shader pipelines
Sound
Dolby 5.1ch, DTS, LPCM, etc. (Cell- base processing)
Memory
256MB XDR Main RAM @3.2GHz 256MB GDDR3 VRAM @700MHz
System Bandwidth
Main RAM 25.6GB/s
VRAM 22.4GB/s
RSX 20GB/s (write) + 15GB/s (read)
SB< 2.5GB/s (write) + 2.5GB/s (read)
System Floating Point Performance
2 TFLOPS
Storage
Detachable 2.5" HDD slot x 1
I/O
USB Front x 4, Rear x 2 (USB2.0)
Memory Stick standard/Duo, PRO x 1
SD standard/mini x 1
CompactFlash (Type I, II) x 1
Communication
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 3 (input x 1 + output x 2)
Wi-Fi IEEE 802.11 b/g
Bluetooth 2.0 (EDR)
Controller
Bluetooth (up to 7)
USB 2.0 (wired)
Wi-Fi (PSP)
Network (over IP)
AV Output
Screen size: 480i, 480p, 720p, 1080i, 1080p
HDMI: HDMI out x 2
Analog: AV MULTI OUT x 1
Digital audio: DIGITAL OUT (OPTICAL) x 1
Disc Media
CD PlayStation CD-ROM, PlayStation 2 CD-ROM, CD-DA, CD-DA (ROM), CD-R, CD-RW, SACD, SACD Hybrid (CD layer), SACD HD, DualDisc, DualDisc (audio side), DualDisc (DVD side)
DVD: PlayStation 2 DVD-ROM, PlayStation 3 DVD-ROM, DVD-Video, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW
Blu-ray Disc: PlayStation 3 BD-ROM, BD-Video, BD-ROM, BD-R, BD-RE
OTHER SITES: http://www.cgno.com/news_live.php?name=sony
http://home.btconnect.com/hgi/ps3/ - 1 of 8 SPEs reserved for redundancy
Blu-ray Disc sounds neat
So basically, Xbox's are going to continue to use the current generation of disks aka WE CAN STILL COPY them.
Good luck copying blu ray disks, atleast for a while
PSiedTSi wrote:
they basically did it to be the cheapest on the market...not the best...it was a value thing...i believe they struggled to decide whether or not to have a dvd player right up until the end...a big part of their decision was also because nintendo has always been a target for piracy. back with their cartridges they were fairly easy to copy.. which is one of the reasons they went with the smaller disks. as far as i know, you still cant copy them as easily as xbox/ps2 games.
99slowGSX wrote:
What about the Nintendo Revolution?
aliengotpsi wrote:
So basically, Xbox's are going to continue to use the current generation of disks aka WE CAN STILL COPY them.Good luck copying blu ray disks, atleast for a while
still sounds neat..
Also note that consoles don't have to drive the same level of graphic detail as the computer based games. Even HD (1080i) is less resolution than anyone would consider running on a home machine for games if they're a gamer. 720p would be a bit more impressive, but still, the point is consoles can get away with lesser video cards because they're not driving the same resolutions as a computer.
Sony has finnaly gave some power to their playstation and hopefully they can market it right to recieve good sales.
