  4. Spring Options?
Spring Options?
11 Posts 8 Posters 757 Views
    awd95mn
    My car definately needs to be lowered. When I put my 17s on it the gap is pretty big. I want a spring that has a good ride. I dont want it too stiff. i also cant go very low because I have to go down a little gravel to get to my house. What options do I have? I would like to maybe buy locally. I only have about $400 to spend on this. What do you guys think?
      idk if they make sprint springs for 2g's but thats a good spring, tein makes good springs too..
        H&R, Tein, Cusco, Eibach, and Espelir all make good springs. Not sure whats available for the 2G specifically, but I'd be willing to bet that all the above listed would be a good choice if they are available. Tein for sure makes S-Tech's for it, and H&R makes a couple sets as well
          Eibach and Tein are prob the most common spring for a 2G
          Tein S-Tech's are pretty cheap... I think under $150
            awd95mn
            the s-tech looks right for me. do you think I would also need some kind of camber kit or would I be alright? they drop the car 1.3"
              Well you should technically ALWAYS get camber kits installed if you lower your car, but some cars have adjustments in the suspension. The front of a 2G is not adjustable at all, but I believe there is some in the rear, hell I forget. Maybe get an alignment just to see how far off it is, and then do camber kits if needed. Most places will "warranty" their alignments for a while, so you could take it back and say that it needs to be re-adjusted or something!
                awd95mn
                or would my best bet be a coilover setup? what do some of you guys have?
                  tein basics bang for the buck in coilover area
                  • darkelvisD Offline
                    darkelvisD Offline
                    darkelvis
                    I have a set of coil overs still in the box (paid $500) for them. I didn't get to put them on before I sold my eclipse. Hit me up if you are interested. CHEAP!!!
                      what brand?
                        darkelvisD Offline
                        darkelvis
                        R1 (i think made by hyper). It is the only brand that Radioactive (in grand forks, before they went out of business) carried at the time.
                        EDIT: I'll be putting these in classifieds soon.
                        EDIT AGAIN: They are in the classifieds with pictures.
