  3. Run Your Mouth
  4. F*** all
F*** all
24 Posts 17 Posters 3.0k Views
    shitty, hope it works better for ya soon
      lol....you'll learn!!! keep trying buddy!
      • legacy-user-33L Offline
        legacy-user-33
        So much hatred in this world.......
        -Tin-
        -IS300-Black on Gold-
        • Hocus Focus 2001H Offline
          Hocus Focus 2001
          take a deep breath and drink some beer LOL
          2002 Supercharged Ford Focus SVT
          #3617 of 4788 - its nice to know your place in the crowd!
          • lord_deastofactL Offline
            lord_deastofact
            I feel for ya man, I just pulled my engine yesterday and it took me damn near half an hour to pull the bumper off, 4 bolts for it were stuck and inacceable. I so wanted to just tourch it and call it a crazy mod.
            Minute ricer!
              tell us how you really feel....
                it will be ok, it will be all good in the end.
                  It's kinda like when you install your first cd player and something doesn't work so you pull the dash apart 3,4 or 5 times then finally realize, that you just blew a damn fuse.
                  The satisfaction of doing it and finally getting it done and knowing you did it yourself will greatly outweigh all the bullshit you went through to put it in.
                    Hocus Focus 2001
                    ^that is very true!
                      sell the bbk and buy a K&N FIPK, i know where to get for cheap
                      • ticklemedalyT Offline
                        ticklemedaly
                        you know, you remind me of "lil brudder" from www.homestarrunner.com , no matter how hard he tries, he just doesn't give up......keep on going lil brudder, keep on trottin!!
                        XBL G-tag: TickleMeDaly83
                          Don't worry all that hp that you will gain with the intake will make it worth it.
                          I installed an intake on a 99 V6 Stang a few years back and that only took maybe 1/2 hour. I am not sure why it would take so long for your car.
                          • theobliviousT Offline
                            theoblivious
                            its in now. lol i saw it today and it looks pimp. the car died though when
                            BOOST....to be continued
                            • StangerBanger96S Offline
                              StangerBanger96
                              Ok so me and my mom put it in this morning, finally. Amazing how much easier it was with a 2nd person. After we finally got the piping fit in and through the rubber thing that kept popping out on the fenderwell mount, it went like a breeze (prettymuch). Got everything reattached and it worked, there is a little bit of a difference, not much, but i wasnt expecting to drop 4 seconds or anything. Then when me and kenn were gunna go to BK today i started it up, it was idling REALLY bad, then died. Popped the hood and one of the hoses had come off from the piping so we went to wally world and bought some hose clamps and it works fine now, there might be a small air leak somewhere but i'll get that checked out when i care. My check engine light has also been on for awhile and we used our scanner and it said "mixture too lean" so some advice would be to disconnect battery, let the computer die, and then start it up and let it recalcuate everything? or what should i do. At least its on now, thanks for the ... non flamish replys to my venting
                              • 5 Offline
                                5 Offline
                                50stang
                                I would start by doing what you said... and see if the computer can calculate the air/fuel mixture correctly again. If it still comes back after you reset the computer... it might be time to replace your O2 sensors. Another think to check is your mass air sensor. Try and clean it off. That can throw everything all to hell too. Good luck.
                                • dubbsyD Offline
                                  dubbsyD Offline
                                  Stupid rubber pieces that are supposed to hold the oxygen sensor
                                  I'll assume you're meaning ACT sensor?
                                  but yeah, check for leaks, unhook the battery (or pull the EEC fuse in the fuse-block under the hood...however on a mustang/3.8L I couldn't tell you which one it is)...
                                  Make sure your MAF and ACT sensor is plugged in (should be a breather or two as well, make sure those are secure and there aren't any holes/bungs unused/open).
                                  How is the MAF positioned with the tube? It's been argued that a bend directly before the MAF causes an inaccurate reading (airflow isn't uniform across the diameter of the MAF).
                                  and like 5.0 said, clean the MAF. Q-tip and rubbing alcohol IIRC.
                                  And it's an Intake Tube... the Intake bolts on to the heads, then the plenum, and throttle body, and then the intake tube. (just a little pet peeve I've got)
                                    StangerBanger96
                                    So here is the visual explanation now....
                                    in the first picture, the yellow circled areas were the things that made the install hell. The stupid strut support is right in the way and allows NO room to work with after the piping is under it. Then the stupid sensor i circled (dont know which one it is, 02?) didnt fit in the hole so they supplied the stupid little rubber piece to make it sit in place, but that was the piece that kept on popping right through and falling into the piping, requiring me to take the whole piping apart again. Then that last clamp was a problem lastnight and a breeze this morning just because there was about..ohhhh.....2mm between the 2 pipes when the lower pipe was all the way into the fender and the upper one was on the TB. Then when i got this all in and working today, the part that disconnected was the pipe leading from right above the BBK emblem to the plenum, so i just put that pipe fastner over it and hopefully everything holds.
                                    Then we move on to image 2. The hole in the fenderwell where the piping slides through had the same thing the 02 sensor had, where whenever i would try slide the piping through the rubber part would bend, fold, and pop through the hole and down into my damn fender.
                                    And yes i have a very dirty engine bay 😄
                                    • camzaro28C Offline
                                      camzaro28C Offline
                                      camzaro28
                                      worse then mine, now that is sad
                                      but the first post was entertaining, i have been in that same situation..................................wait i am right now
                                      car is down at the moment. waterpump went.
                                      jig 4 prez
                                      • 94NDTA9 Offline
                                        94NDTA9 Offline
                                        "that little guy, he's got the heart of a champion"
                                          how do u not know how to install an intake? haha... JK dustin. Hope your MIL turns off and your car breaks the 20 second barrier...haha
