  3. Track Talk
  4. Racing on memorial day.....
127 Posts 40 Posters 15.6k Views
  • DaveHD
    DaveHD
    heh, well I guess 29.5x10.5 is small compared to what some people run. 😛 I can't get anything bigger than a 28 under my wheel well.
    The track was sticky at first, but it deteriorated quite badly. You car would prob lift the wheels and hook on a gravel road. LOL I know my car would just spin, and Ethan said that he lost all hope of launching his bike well after a hour or two. What is your weight bias front/rear? I noticed that you had ladder bars on there, why not 4-link? (obviously the ladder bar works I guess). The odd thing is that my car had no traction issues other than right on the starting line. I saw that you got loose in the middle on the one pass, my car just drove down the track with no issues. I wasnt spraying so my 1/8 mile mph was only 103-105.
    homer wrote:
    I had the small tires on it (29.5x10.5x15), actually thought the starting line was better Monday night than on Sat/Sun, since track temp was finally decent and there was less humidity in the air & I increased air pressure 1 lb to 8.5 lbs, since had too much wrinkle and was folding tires over when launching.
    The LC6 held up nicely and track actually has too much rubber on it right now & needs to be scrapped. Alot of sand/dirt was on track from cars parking in the dirt/mud than making runs, but that was the fun part for me, seeing if we could stay in the groove & drive through it, (First pass obviously I didn't and peddled it a couple of times to drive back into it) & the groove was tight and their wasn't much room for error.
    **First **pass was a 10.21 @ 133.47, 2nd pass I didn't get a correct time but with Data Logger info and short times was a high nine leaving soft probobly at the same MPH. 3rd pass was decent up to 660' (9.78 @ 140mph) but car nosed over after that and we just missed the tune and are running too lean with the alcohol with 172 jets & I don't think the 4:88 gears are helping like we thought.
    Didn't change suspension, just tire pressure, since only have ladder bar/coil over system and only changes to shock settings and spring rate that I can make will only help on rough tracks.
    Hopefully we get it figured out since car is now slower than it was $7K ago & I am still slower than 2Wheeler :mad:
    PS:
    May 30, 2005
    07:47:40 PM
    2356 DA
    **71.7 Degrees F **
    45.8% Humidity
    57.5 Degrees F Dp
    0.47 Vp
    0.925 ADR
    • P
      P
      pin
      PSiedTSi wrote:
      were you running slicks?
      Yes, hence the mention of slicks in my post.
      Barry
      • PSiedTSiP
        PSiedTSiP
        oh i didnt even realize that at the track...i assumed that by your post but i wasnt sure...
        spanish-rice;237125 wrote:
        • LT1L
          LT1L
          LT1
          • P
            P
            pin
            caption for the last picture - "Thanks for topping off my radiator, harwood."
            Barry
            • PhatsP
              PhatsP
              Phats
              STiSchucky wrote:
              hmm. i have a boost controller set at 16 psi, headers and turbo back exhaust...maybe once he gets those, he'll be up there with me in the low low 13s.
              Yeah that's what he's waiting for......he was pretty frustrated 'cause he saw you running low 13's so he thought he should be right there. He's a good friend of mine, and since i've been through the all-wheel-drive woes, and figuring out the launches, i was trying to help him best i could.
              02 GSXR-1000
              97 540i
                HandoEX wrote:
                Maybe try some weight reduction 😉 😉 😉
                or maybe he could put a 350z motor in it and run faster then the Z its self
                • F
                  F
                  fanaticrockford
                  I'm trying
                  • F
                    F
                    fanaticrockford
                    Ok Smart ass i know a rwd motor will not fit in a fwd. I could use the same 3.5 platform though.
                    The fastest 3.5 NA 350z i have seen ran a 13.1
                    The fastest 3.5 NA Altima i have seen ran a mid 13 (unsure though)
                    The fastest 95-99 3.5 Swap NA Maxima runs a 13.3
                    The fastest 02-03 3.5 NA Maxima ran a 12.8
                    Thers the proof. Most 350z's run low 14's and some high 13's
                    • XJHEADX
                      XJHEADX
                      camzaro28 wrote:
                      fargo what happend to ur car? guess it wasnt anything bad
                      They saw a drop of oil on the ground coming out of the b/out box :rolleyes: :rolleyes:
                      • STiSchuckyS
                        STiSchuckyS
                        heh, him and the white sti were runnin similar times. Is your buddy even on this site?
                        • bluejaysB
                          bluejaysB
                          bluejays
                          i know the guy, he is on the tintmaster site. he is not on this site though. i told him about it though.
                          • DaveHD
                            DaveHD
                            Does anyone have pics/vids from Memorial Day? I was usually messing with my car so I didn't get much of a chance to watch.
                            • JimJ
                              JimJ
                              I don't get your point? "Most" Maxima's prob run 15's or 16's......
                              • homerH
                                homerH
                                homer
                                They saw a drop of oil on the ground coming out of the b/out box :eek:
                                Ford guys, you'd think with the amount of horsepower they build & as smart as they are, they would either:
                                1. Have an engine that didn't blow the dipstick tube out
                                or
                                1. Follow the rule book and have a positive lock oil & trans dipstick tube
                                Sorry Bill, Couldn't resist.........................
                                "Will Work for Food"
                                  i have a vid of monday and will be getting it online by next week
                                  • DaveHD
                                    DaveHD
                                    Homer, whats up with selling your fast car and all the stuff with it?
                                    Dave
                                    homer wrote:
                                    :eek:
                                    or
                                    • homerH
                                      homerH
                                      homer
                                      I think I am going to take up Fishing & Buy a "Hot Rod" Ford Focus :rolleyes:
                                      or maybe start fixing up my Funny Car :eek:
                                      • DaveHD
                                        DaveHD
                                        LOL! I know you really just want to run a street car on the Street Legal nites and quit that silly bracket racing.
                                        Dave
                                        • N
                                          N
                                          NightriderWRX
                                          so why are people bashing other people's track times?
                                          2004 WRB Subaru WRX STi
                                          350awhp pump 93 octane
                                          430 awhp c116
