thrown timing belt on DSM
treimche wrote:
I would just sell the car to me for cheap since the motor is probably f'ed and you probably don't want to deal with it!
that's funny troy, don't you have enough problems with your 2g? why would you want to deal with a 1g? -
out there wrote:
bad idea. how do you know that the used replacement motor hasn't been treated even worse? there's no guarantee with so many moving parts, buying someone else's used car/engine/tranny/etc is buying someone else's problems. i would just put work into the engine already in the car1st....Owning a used dsm = IT HAS BEEN TREATED LIKE SHIT IN THE PAST!!!!!!!!!
2nd...Most used engines come with some kind of a warrenty, which is why I suggest replacing most of the critical things while it is out in the open. When the engine is removed from a vehicle and is in known working order, they usually check compression too, mainly because they dont want to send out a motor that may be running only on 3,5,7 cylinders.
3rd....This is from MY EXPERIENCE....both from owning a dsm and being a technician. They are a pain in the ass trying to fix when the valves have been bent....And there is always at LEAST 4 bent (intake and exhaust on 2 cylinders at once)
my .02 cents
97Cav wrote:
that's funny troy, don't you have enough problems with your 2g? why would you want to deal with a 1g?owning a 2g = problems....
owning a 1g = problems....
owning any mitsu with high miles = problemsGreat motors, horrible to work on.
i suppose neither one of us specified where the used engine would be coming from...
if the head is the only thing damaged, just send it off to buscur, ffwd connection, turbotrix, fasterthanyou, etc and get something better back
keep in mind, this is IF the head is the only thing damaged. i would take it to someplace that knows the engine before i even think about keeping it (for reasons that ryan mentioned) -
i wasnt mine but they fixed it it seems to be fine/
slowvo wrote:
Owning anything making any power = problems
your stock honda = reliable.horrible to work on? haha....what do YOU work on?
what do "I" work on?? anything and everything. I'm not some punk who thinks he knows everything, I'm actually a trained and certified technician. Hell, I put motors in 2 different talons this past month because of timing belt failure.
eatinup_pony_racer wrote:
i wasnt mine but they fixed it it seems to be fine/give it time....unless they're lucky?
PSiedTSi wrote:
wait so it just bends 1 of each in 2 cylinders?explaination....16 valve engine, 4 per cylinder, 2 intake and 2 exhaust per combustion chamber....
say cylinder 1 was on the intake stroke, so the 2 intake valves would bend, while the cylinder 4 was on the exhaust stroke, it would bend the 2 exhaust valves, but if it caught it among the floating part while all 4 were open on the intake stroke....called valve overlap....there is a chance it would bend all 4 of those, but very rarely. on a dsm, 1 and 4 are at tdc, while 2 and 3 are at tdc.
thats cool, we all get tired once in awhile
still waiting :rolleyes: ......unless you are asking
? if you are or someone wants to know, it is top dead center which is the very top the piston reaches in the cylinder
i was doing some research on cams a while back, so i know already, just wondering how long it would be until someone asked "what's tdc??"
treimche wrote:
I was just curious as to why you replaced the WHOLE motor in those 2 talons since they had timing belt failures? Were the bearings shot or have holes in the pistons or something?
ditto. depending on several factors of when the belt failed, i would expect that a piston or two might have been ruined, not to mention at least one other issue -
here we go
ticklemedaly wrote:
Most of the time on a dsm the teeth get ripped because something is causing way too much drag on the belt. Most cases it is the oil pump. They are notorious for having low oil pressure when the mileage gets high, mostly caused by owners not changing the oil every 2k miles like they are suppose to and becoming a hell of a drag on the system due to worn parts.I guess i cant say ive ever seen an oil pump lock up on a DSM, but then again, i dont touch them anymore...
im guessing a coolant pump would be a bit more likely.Trained and certified? fuck, even I am trained and certified. It just dont mean shit.
slowvo wrote:
here we goI guess i cant say ive ever seen an oil pump lock up on a DSM, but then again, i dont touch them anymore...
I havn't seen them lock up, but I have seen them have so much drag on them that they dont lubricate the whole engine....this speaking from experience with a 91 tsi I used to own. caused the belt to have teath ripped off and bent 4 valves....
As of the engines being replaced....it has gotten so cheap to get a used engine and install it, compared to disassembling it and fixing the damage done to it, and not having a decent enough warrenty to cover a long period of time.
And trained and certified?....Just backing my ass up so others dont think that I dont know shit, you have to have some credentials. Yes, a good backround of having many years of experience is good too, sometimes even better. But most businesses and customers want a mech/tech that has credentials too. Plus they pay better.
