  4. thrown timing belt on DSM
55 Posts 17 Posters 3.1k Views
  • ticklemedalyT
    ticklemedalyT
    ticklemedaly
    thats cool, we all get tired once in awhile 😉
    XBL G-tag: TickleMeDaly83
    • O
      O
      how long before someone asks you to explain what tdc is? 😉
      • ticklemedalyT
        ticklemedalyT
        ticklemedaly
        still waiting :rolleyes: ......unless you are asking 😛 ? if you are or someone wants to know, it is top dead center which is the very top the piston reaches in the cylinder 😄
        • treimcheT
          treimcheT
          I was just curious as to why you replaced the WHOLE motor in those 2 talons since they had timing belt failures? Were the bearings shot or have holes in the pistons or something?
          • O
            O
            i was doing some research on cams a while back, so i know already, just wondering how long it would be until someone asked "what's tdc??"
            ditto. depending on several factors of when the belt failed, i would expect that a piston or two might have been ruined, not to mention at least one other issue
            • S
              S
              slowvo
              he said because the oil pumps go bad so often on high mileage dsm's and oil pressure drops.
              yup! thats it.
              • S
                S
                slowvo
                here we go
                ticklemedaly wrote:
                Most of the time on a dsm the teeth get ripped because something is causing way too much drag on the belt. Most cases it is the oil pump. They are notorious for having low oil pressure when the mileage gets high, mostly caused by owners not changing the oil every 2k miles like they are suppose to and becoming a hell of a drag on the system due to worn parts.
                I guess i cant say ive ever seen an oil pump lock up on a DSM, but then again, i dont touch them anymore...
                im guessing a coolant pump would be a bit more likely.
                Trained and certified? fuck, even I am trained and certified. It just dont mean shit.
                • ticklemedalyT
                  ticklemedalyT
                  ticklemedaly
                  slowvo wrote:
                  here we go
                  I havn't seen them lock up, but I have seen them have so much drag on them that they dont lubricate the whole engine....this speaking from experience with a 91 tsi I used to own. caused the belt to have teath ripped off and bent 4 valves....
                  As of the engines being replaced....it has gotten so cheap to get a used engine and install it, compared to disassembling it and fixing the damage done to it, and not having a decent enough warrenty to cover a long period of time.
                  And trained and certified?....Just backing my ass up so others dont think that I dont know shit, you have to have some credentials. Yes, a good backround of having many years of experience is good too, sometimes even better. But most businesses and customers want a mech/tech that has credentials too. Plus they pay better.
                  • S
                    S
                    slowvo
                    What does drag on a belt have to do with lubricating the whole engine?
                    in theory, if a oil pump is getting bad, there is more play in the gears, which would make less of a drag.
                    It would have to be one hell of a drag to load the belt enough to shear the teeth off of it.
                    Has anyone ever seen a oil pump coked up so much that it wont spin? or there is a big drag?? I personally have seen many oil pan's and pickup's clogged with gunk that you have no/low oil pressure, but never had a problem with the pump itsself.
                    Now from a shop standpoint, i can see why one would want to replace the entire engine. its easier to do, less to screw up, warranty, ect.....but done right, its not too hard, and pretty common to just do a head.
                    As far as a pay standpoint, pretty much all dealers have standard pay rates. it doesnt matter what your credentials are, age, skill, ect. It comes down to how efficent you are at diagnosing and fixing cars. I know guys that never went to school, have no credential's, and get paid the same (or more) as the senior tech that is ASE master/L1, master certified in their line, Ect.
                    customers dont care about individual's, just hang a ASE sign up, and they will be happy.
                    • O
                      O
                      ever seen an alternator with bad bearings? can you say goodbye belt? i have had 2 alternators die in my saturn (can't handle excessive high rpm driving apparently), and what ryan is saying about drag is true. in fact, with the first one (died about 1.5 years ago in the winter) i could see smoke and sparks coming from under the engine when i looked to see what the smoke coming through the vents was coming from. needless to say, i stopped driving it that night and took it in the next morning.
                      • treimcheT
                        treimcheT
                        Yeah I think that replacing the complete engine is unnecessary also. 9 times out of 10 when a DSM timing belt fails or breaks, it bends a few valves or all the valves, so you have the head rebuilt with new valves, put it all back together properly and you're good to go. No sense in replacing a complete motor when the bottom ends in these things are very very strong. I could see replacing the motor maybe IF the oil pump was locking up like that. That means that there's something getting into the oil pump and chewing up the oil pump gears, or the case, or both. But that would mean that there's metal coming from somewhere else in the motor, so then it could actually be justified to replace the whole motor. Now about the whole used motor part of this, I don't think it's nearly as wise to get another used motor instead of having one rebuilt. I would much rather see someone rebuild the motor that they have, that way you KNOW that everything in there is good, and not all beat up by whoever the jackass is that had the motor before you. And honestly, if you price it out, getting a motor rebuilt really isn't all that expensive, and could possibly even be done for the same price as a used motor. Plus that way you have all new gaskets, timing belt, oil pump, water pump, etc..... That's my $0.02 anyways.
                        • S
                          S
                          slowvo
                          are you talking about a timing belt?
                          • ticklemedalyT
                            ticklemedalyT
                            ticklemedaly
                            Yes, ideally it is best to have the motor rebuilt....but after you concider all the little things involved with rebuilding it and show the estimate to the customer, and actually find a used one and show that estimate to the customer....9 times out of 10 they dont want to shell out the extra cash and just have a used one put in.
                            Also, if the oil pressure hasn't dropped enough, it is possibly ok to have it serviced and everything else done too at the same time...but it ends up being as much or more. The one I had didn't lubricate the balance shaft enough to were it dug a huge hole in the block, oversizing it enough to were the only way for me to save it is to have a bearing about 1/4-3/8" thick all around. And this is the balance shaft that is drivin directly by the oil pump. I should have just placed a used engine in it, I regret it to this day.
                            But as of the others, both had enough damage to were it was CHEAPER to place a used engine in it.....customers love things that are cheaper.
                            And for the credentials....I HATE DEALERS!!!! Mainly because all they want are techs with experience, and even if you do, it is still hard to get employeed by them. And for pay wise, I make more than most of them, only ones that make more are the ones with at least 20 years of experience and have been with that company the whole time.
                            • JimJ
                              JimJ
                              Ok... unless I'm confused, the last time I checked: replacing valves in a head, machine work, whatever else <200. Used motor 1500-3000
                              • bluejaysB
                                bluejaysB
                                bluejays
                                jim, remember normal people have to pay labor for all that stuff. 😄
                                • JimJ
                                  JimJ
                                  I know that... those prices were not including labor.
                                  Cost on a used, working, warrantied engine is 1500-3000
                                  • integra_gsr98I
                                    integra_gsr98I
                                    Labor on most swaps is well over $1000 alone.
                                    I think a valve job under $1000 with new water pump, timing belt, balance belt, sounds like a damn good deal to me.
                                    • O
                                      O
                                      accessory belt, but the idea about drag is the same
                                      • B
                                        B
                                        burnteclipse
                                        Questions for the same topic....i know there is a few set mile intervals where dsms should replace the timing belt does anyone know of what that is off hand?
                                        • S
                                          S
                                          slowvo
                                          Damn, i gotta quit and join the aftermarket shops, thats where the money is at.
