  3. ICE and Detailing
  4. I need some cd deck help.
16 Posts 5 Posters 3.0k Views
  • OSAO
    OSAO
    OSA
    Ok, well, I was helping my cousin hook up a new deck for his old Chrysler Labarron(sp?) Anyway, it's an old car. After we were all done, and turned up the volume sound came out, but so did static. The static only came when it was louder setting of volume, or with the "loud" option turned on. The car has 5 speaker wires, 2 power(+ and ground/-), anttena, and some braded silver wire that was on the old stereo. There's only 1 negative speaker if I'm correct, unless I wired it wrong, and 4 positive, one for each speaker. I was thinking it's due to the one negative wire for all 4 speakers. Or mabye I wired something wrong/forgot to wire.
    Anyone know what might be wrong? 😕
    Thanks in advance!
    legacy image <--Like my ride?
    • amichezeA
      amichezeA
      it could just be the cd player distorting too. i have a really crappy aiwa one right now that disorts when it gets too loud. check all the wiring and make sure its all correct and theyre all connected tight, then check to make sure its not a blown speaker.
      if its not any of that, it might be because of what you said. im sure tjamz will say for sure.
      Fargostreet Trolls wrote:
      i must be stupid
      • OSAO
        OSAO
        OSA
        Thanks amicheze.
        Mabye it's a combo if a few things. The two front speakers are factory speakers, so they're way over 20-30 years old, and are probably blown. Along with the combined all to one negative. I'll see if they're the problem tomorrow when he comes over.
        Any other ideas why it might be staticy at high volume?
        • JimJ
          JimJ
          it's dead people trying to talk to you... (white noise lol)
            It has what is called a common ground speaker wiring. This cars system only uses 1 physical wire (the positive speaker lead) to send a the + signal to the speakers, it uses common ground to send the negative signal. What you need is a floating ground adaptor OR you need to run a fresh pair of speaker wires to each speaker in the system.
            here is some more info
            http://www.installdr.com/TechDocs/999003.pdf
            • OSAO
              OSAO
              OSA
              Ahh, that movie rocked.
              Thanks, tjamz, I really apprecaite it.
              I think re-wireing would be the cheapest way of doing it. Since I already have some spare wire. Although I've never re-wired a car myself.
                its pretty easy....2 wires to each speaker from the deck...
                  sounds complicated to me...2 wires...thats 2 2 many
                  • OSAO
                    OSAO
                    OSA
                    Well, I don't want the wires showing on the ouside. Then it'd looked crappy. Atleast to me it would.
                    • T
                      T
                      TRE
                      rewire all the speakers for sure, common grounds are no good for aftermarket cd players
                      • OSAO
                        OSAO
                        OSA
                        Success! No more ghost sounds. Heh.
                        Thanks again, espcially tjamz, thanks man.
                        • amichezeA
                          amichezeA
                          glad to hear its working.
                          i must be stupid
                            no problem, glad to help
                              nice sig pic! lol
                                • OSAO
                                  OSAO
                                  OSA
                                  lol Thanks. I'm almost done fixing it too. It'll have some sweet white headlights, hood and bummper.
