Im new to the scene
good to see you signed up torb...i'll get ur pics posted sometime tonite.
wassup pimpin, glad to see u signed up.
Jim wrote:
If you have a T-25 you shouldn't be concerned with a turbo timer... waste of money
I am going to have to go ahead and agree with Jim on this one. If you want to prolong the life of your turbo just wait those extra 15 seconds or so in the car and let it idle. -
welcome to the forum
welcome to the site
alright . thanks for the advice on the timer.
T-25 ... it's stock! If the factory had thought it was going to blow up becuase it wasn't turbo timed, they would have put a turbo timer in it!
A larger turbo I can understand...
Just don't like go do 10 highway pulls in a row and shut your car off as soon as you let off the gas. As long as you run the car even just a little bit (not boosting) then you should be more then ok, no need to sit in your car for a minute and let it idle...
shut up jim t-25's boost at idle!
MWC1 posted under slowgst
j/k
thanks for the advice jim, i will probably get a turbo timer sometime when i upgrade everything.....
