  4. Need Help!!!
Need Help!!!
18 Posts 10 Posters 1.3k Views
    check all the vacuum lines carefully for tight fit, also check your intercooler pipes...that part can be tricky and look good until you actually put it under a load(find a way to pressure test it)
    • W Offline
      W Offline
      Wizard
      And the cam sprocket on that motor is a bit tricky to line up since it has technically 4 ways to install. Get a book and make sure it's right.
      Wiz
      1992 GVR4 598/1000 Nile Black
      1992 Tsi AWD
      1982 Datsun KC 4x4
      1990 Laser 2.0 AT NT
      1994 ES 2.0L NT 5-spd
      • McAdamM Offline
        McAdamM Offline
        McAdam
        easy way to check for bost/vacuum leaks....
        get a can of starting fluid and spray it wherever there is a connection at idle. If you spray a hose connector (I.E. intercooler piping) and idle picks up, there is a leak.
        I know nothing of the Probe/MX6 engines in particular, but the way it sounds like it isnt running, it reeks of cam timing being off.
        McAdam
        • 9 Offline
          9 Offline
          98chevy
          McAdam
          Well, the car is running fine, when the car is at idle, u press the gas and the response is there, so I dont think it is the timing, but I am going to check it this weekend with a timing light, u prolly know more than me, but what the the main purpose of the MAS (mass airflow sensor)??? kinda just curious, cause when we plug the MAS in, the car dies... ??? Im not a damn mechanic, im just a electrician....lol
          "If at first you dont succeed, use a bigger hammer!"
          • W Offline
            W Offline
            Wizard
            Try starting the car with the maf plugged in. Will it stay running. Also, try proping the flapper open and see if that helps. Easy way to check for boost leak on a 5-spd car is to unplug the maf and rev the motor. She'll load up with fuel and build some boost. The carb cleaner/starting fluid idea only really works for a vac. leak. Boost leaks often don't appear until under a load (boost).
            Also, is the turbo even spinning? What about the exhaust? Clogged?
            Wiz
            1992 Tsi AWD
            1982 Datsun KC 4x4
            • 9 Offline
              9 Offline
              98chevy
              Wiz
              k, well try those ideas, we r going to tear into it on sunday, so hopefully we can get it to run decent and boost, thanks all for all the help and suggestions, all is appreciated....
              • lord_deastofactL Offline
                lord_deastofact
                OK I hate to have to say this, but I think this problem is beyond my ability to fix and my knowledge about cars. So does anyone know where I could take the car to get it checked out, I am on a budget, so someplace that does decent work for a decent price would be what I'm looking for. I would really like to see the car running nice again, but right now I'm so pissed at it I would just sell it. any idea's on shops let me know. Thanks
                Minute ricer!
                  http://www.fargostreet.com/showthread.php?t=1100
                    PM 92tsiPOS, he makes house calls,lol, and worked on my car before you bought it. we made mine run, so i'm sure he could help you out. Otherwise, PM fallguy.
                    If you want to just have it done, bring it to SLS, Tintmasters, or roadsounds. Personally, i bought parts from Shane and Nick, both helpful. Never had any experience but only heard the best. Also check out Advanced Autowerx. Jake knows a thing or 2...
                    • 91nbtsi9 Offline
                      91nbtsi9 Offline
                      Um, if you don't know what the MAS does, might want to take it in! heh. It is what the ECU uses to measure the amount of air coming into the engine. It uses that value as one of the MAIN variables in calculating the amount of fuel needed, and hence the injector pulsewidth, etc. FYI don't run the car around without the MAS hooked up, as it just runs off a default sensor parameter and could possibly be very bad for your engine. By the sound of it, you have a HUGE vacuum/boost leak. First thing to check, also definately verify you have it timed correctly, both cam timing and ignition.
                        pin
                        I didn't read this entire thread, but did you try a different VAF(the air flow sensor, it's not an MAF)? Since the car dies when you plug the connector in, it's a possibility that the VAF has gone bad.
                        Barry
                          I have one, that technically is yours. come get it!
