Bluish/pruple second gen probe?? heavy rice content...
If it is the guy im thinking of, it is a bosnian. He came to me last week wonding if I can fix his belt squeal, but since his body kit is completely shaved into the car, there was no way we could have lifted it up to do anything at all. Just looking under the hood, it looked like he had some nitrous or somthing, he also had the toggle switch in it too. He is selling it. It is more of a deep purple with hood pins. runs like shit.
I think I've seen him. Is he a foriegner? If it's that straight up purple probe with the full kit and wheels, that thing is actually pretty clean but he claims it's fast. (What duner doesn't think their car is fast?) Revenge of the ricers shall crowd the streets of Fargo ND this summer. God help!
He works at culvers on 13th. I've heard from some other people too that he tried to race them, then backed out at the last second.
bluejays wrote:
he has 2 a/f guages. lmaoMaybe he thinks he needs one for air and one for fuel.
It's a sweet looking car until you get a chance to look under the hood. I took a look at it the last time I was at Interstate Dragways, and I noticed wrapped headers and possibly a fuel line modification to improve the fuel distribution. A lot of people do what's known as a "dual feed" modification to the fuel rails as #6 gets short-changed a bit. If he has a nitrous setup, I didn't notice that.
bluejays wrote:
he has 2 a/f guages. lmao2nd Gen Probe GTs have a 2.5 Liter V6.
The dual feed fuel setup that pin mentioned helps insure even fuel distribution. 2nd Gens are plauged with factory side feed injectors the are fed in series, causing the 5th and 6th cylinders to run lean when extra fuel is required (F/I or Nitrous applications). Splitting the pressure side and combining the return helps equalize fuel pressure to the injectors. There are a few GT owners that I know of that run dual A/F gauges to make sure that both banks of the motor are running sequentially. When I wire my fuel computer I plan might wire in both O2 sensors to monitor/log both banks of the motor when I am not running my wideband.
I don't know the individual who owns the car and haven't had a good look at the car or its modifications. Based on the appearance of the car and behavior of the driver I am led to believe most is probably fluff. Oh well, there is your 2nd Gen Probe edumication for the day.
Lucas
