  4. exhaust system prices
26 Posts 15 Posters 1.8k Views
  • JoelJ
    JoelJ
    or just get press bent then, since you aren't going forced induction. It'll save you a lot of money.
    • JimJ
      JimJ
      Well the people at cavalier forums must be retards...
      2.4l 4 Cyl...
      You still have a cat, the backpressure is still there... 2.5inch vs. 2.25...
      I highly highly doubt your going to loose any power from having larger exhaust, more likely it will just be more high flowing.
      Here's the thing though, your not talking about freeing up much hp either way from bolting on exhaust... so whatever you do you prob wont notice a huge difference. If your looking to do it cheap, just visit somebody like muffler man and have them press bend them as it prob wont even make a huge difference anyway
      • wesholeW
        wesholeW
        I'm running 2.5 inch on a 1.6 liter engine. I certainly didn't loose any power by doing so. If you cant afford it right now, then hold off on doing it untill you can. I know how it is to want to get it done especially with the parts right in front of you, but I also firmly believe in doing it right the FIRST time. Don't mess aroud with pressbent pipe. Alot of times, the actual pipe diameter is down too well under 2" inside diameter when the bends are made and your exhaust only flows as well as the smallest piece will allow.
        • JoelJ
          JoelJ
          why would he waste that money tho. He doesnt need high flowing exhaust. hes stock.
          • T
            T
            tyklein8
            My muffler has a 2.25 inlet and then my cat. has a 2.25 inlet and outlet. Would that be a problem with 2.5 inch piping.
            95 Eagle Talon TSi AWD...[B]LONG GONE[/B]
            2008 Honda Civic Si: Razo weighted shift knob, nokya yellow drls, 4500k ddm hids, k&n drop in filter
            15.38 @ 91.39
            • wesholeW
              wesholeW
              I'm still stock also except for the air filter/adapter under the hood. You gotta start somewhere. So let me get this right, You need some major shit done to your car now to have exhaust done for it to be justifiable? Oh shit then Tufte I need to turbo my car NOW!!!!!
              • JoelJ
                JoelJ
                yes YOU DO!
                • P
                  P
                  pin
                  tyklein8, did you check with FM Exhaust and Brake?
                  Barry
                  • T
                    T
                    tyklein8
                    Yeah i checked at fm exhaust and brake, but i have an appointment for thursday at exhaust pros for 2.5 compression bends for about $145. Should be a pretty good system i think with my magnaflow muffler and converter.
                    15.38 @ 91.39
                    • JimJ
                      JimJ
                      You do know you could have gotten muffler, and cat-back exhuast for $199 mandrel bent on ebay...
                      • P
                        P
                        pin
                        I was at FM Exhaust getting a muffler installed when you stopped in. That's an interesting coincidence.
                        Barry
