  4. Tonight, Saturday Night.....
29 Posts 14 Posters 1.5k Views
  • jct_4628J Offline
    jct_4628J Offline
    jct_4628
    dubbsy wrote:
    yeah, good times last night.... although I think we need to up the dosage on Harwood's medication....
    I was there also, and I agree. Did u forget to take ur meds?
    Jason
    -06 WRX
    -95 CBR 600F3
    701-541-2568
    • G Offline
      G Offline
      GraveDigger
      I was on my way out there, until my car took a dump last night. Some of your fast cars may be cheaper, but my coverage is worth it.
      GraveDigger
        What coverage are you speaking of?
        • G Offline
          G Offline
          GraveDigger
          10 year/100,000 mile warranty! BOOHYA!! That means redline all you want.
          GraveDigger
            I GUARANTEE if the dealer sees you beating the fuck out of the car, they will have just cause for voiding the warranty.
            • G Offline
              G Offline
              GraveDigger
              I know, not beating the fuck, as you so gently put it, might not get caught, but aftermarket parts will kill me in the end. Now will be the true test, I had a problem, but I took my intake off quick and put the stock one back on, but I will see what happens. I think I might have gotten water in the intake. They can't just void my whole warranty, that's against the law. They can only not replace parts where aftermarket parts are, otherwise, I am all covered.
              GraveDigger
                pin
                How the hell could you have gotten water in your air intake? It's like 6" long.
                Barry
                • G Offline
                  G Offline
                  GraveDigger
                  I don't know, but maybe it was just dirty, or if water got on there somehow, there goes my car. I don't really care just as long as it's covered and gets fixed. They are working on it now.
                  GraveDigger
                  • M Offline
                    M Offline
                    mym6
                    If your check engine light is on I can pretty much gaurantee they'll know more than you think about what caused it. OBDII cars take data snapshots when they give a CEL. Things like engine load, RPM, A/F ratios, vehicle speed are common things captured. If you bring you're car in with the stock airbox on and the A/F ratios are completely wrong they're going possibly diagnose the problem incorrectly.
                    The Magnuson-Moss Warranty Act protects you from having your warranty voided when using aftermarket parts unless it can be proven the aftermarket part caused the problem. Because of this it is your duty, IMO, to be able to scan your own vehicle's computer system with a scanner so you can retrieve code information and look it up. If the code is related to something you did then you should diagnose and fix the issue. If you don't agree with this then don't modify your car.
                    What makes you think you got water in the engine anyway? A small amount of water spray isn't so bad (water injection anyone?) and you'd have to submerge the filter completely to get a real good amount of water anyway. And if you did that you certainly wouldn't be driving it to the dealer for repair.
                      i dont tihnk the dealership you bought it from wouldve cared if you had different intake its not that bvig of a difference as the stock one..so you couldve just left it on.
                      • G Offline
                        G Offline
                        GraveDigger
                        The CEL was never on though. I should have just left it on, but oh well. I didn't want something major to be wrong, then have them not fix it cause of the intake, cause they are gay like that. They just called back, and said that the intake wasn't set up right, one of the tubes. I was just worried that something more majored happened to the engine because of something, or that it was the tranny. It wasn't water then, but I bet my intake was dirty as hell maybe, I haven't cleaned it since I got it. The cleaning kit is 25 bucks, that I don't have right now. When I looked in the first tube off of the TB, it was black at the back, and I take it that means it was dirty as hell.
                        GraveDigger
                          Try telling that to Subaru of America where they have voided warranties on transmissions for guys that have only added cold air intakes/grounding kits. I agree though, the law is written to protect the consumer.
